First post, by Kordanor
Heyho,
got another game which doesn't run properly on GLIDE on my Voodoo 3 within DOS (with some other games I already gave up) .
Lands of Lore 2 is patched and does start, however when Hardware acceleration is active, and I move the mouse I get weird horizontal lines. Also my mouse is a bit floaty.
I already booted the PC with different CPU speeds and tried out different memory configs, and copied different Glide2x.ovls into the directly (btw is there any archive to download these directly and see which ones support a v3?)
So far nothing helped. I found multiple threads about dosbox with a similar issue, but besides of mouselag they mention black boxes which I dont have.
Here is what the issue looks like:
https://youtu.be/lIRPtVltqoY
Edit: Instead of ctmouse, I also tried mouse.com and Logi730 as mousedriver, no changes.
Edit 2: also tried to change non-linear to linear mouse move and checked if vesafix does anything (it does not)
