First post, by polishvito
I have an IBM CGA card from a 5150 that I am working on restoring. The composite output jack is pretty crusty/corroded and the monitor I am using has difficulty syncing up and/or video just randomly cuts out, comes back blurry (even for composite). I’ve cleaned the connector as best I could, used contact cleaner, deoxit etc with minimal improvement.
Anyone know of a suitable RCA connector that can just be a drop in replacement for this one? I know it’s nothing special, Just want to make sure it will fit on the card and in the cutout on the I/O plate. The legs of the original port seem longer than any of the ones I’m finding online.
Edit: any idea if these will fit properly? Fielect 5Pcs RCA Female Jack 3 Pin PCB Mounted AV Concentric Outlet 1 RCA Female Socket Connector Stereo Audio Video Jack https://a.co/d/0TWG2IZ
