maksg wrote on 2021-09-18, 16:55:
The only useful url I've found http://ohlandl.ipv7.net/misc/230MB.html - but the Fujitsu URL seems expired already.
Use the Wayback Machine, my friend! Looks like 2015 is the last time that Fujitsu URL worked.
https://web.archive.org/web/20150724122112/ht … rt/software/mo/
On the other hand, looks like none of the files were preserved. Furthermore, I can't really see which, if any, are compatible with your drive.
Most drivers mentioned there look like they might be for the 230MB drives comparable to the IBM drive you found at http://ohlandl.ipv7.net/misc/230MB.html
** [EDIT] Google claims that there's a partial backup of these files at ftp://cyberia.dnsalias.com/pub/filebase/hw/Fujitsu/
ftp://cyberia.dnsalias.com/pub/filebase/hw/Fujitsu/FILES.HTM
[EDIT] Okay, got you.
In the era of the Fujitsu MCP3130AP , based on my research, you would have found drivers here: http://jp.fujitsu.com/platform/storage/compon … s/mo/downloads/
or maybe here: http://mo.fujitsu.com/jp/archive/
or here: http://www.fujitsu.com/jp/group/personal/supp … /driver/mo.html
I had luck with the Wayback Machine:
https://web.archive.org/web/20130716052533/ht … s/mo/downloads/
Which turned up DOS/V drivers for the SCSI and ATAPI internal MO drives: https://web.archive.org/web/20130416012627/ht … wnloads/dosuty/
Download link works, downloads archive from archive.org!
Problem here, DOS/V is not MS-DOS exactly. English details: https://en.wikipedia.org/wiki/DOS/V
Next possibility: IODATA MOI-AB1.3 allegedly used Fujitsu MCP3130AP internals. So maybe IODATA drivers can work?
Still online. https://www.iodata.jp/lib/product/m/767.htm
Claims to have MS-DOS drivers. Not sure if DOS/V drivers instead.
Good luck. Hope you understand Japanese, you may need to!
Please let us know if any of these work!
Reason: added Cyberia FTP URL
do the Fandango!" - Queen
Stiletto
