First post, by TheCoop
It's been a loooong time since I posted here last, but I'm at a bit of an impasse.
I recently bought a new copy of Jane's ATF (still in the wrapper). It's the version that comes in a regular CD case with a silver border around the artwork. When I installed it, the installer told me it's version 1.00f. However, I also just got a copy of Jane's ATF: NATO Fighters, and it expected the original game to be version 1.03f in order to install. Well, since there's really no patch to bring my version up to 1.03f, I had to do a little digging to find an ISO of version 1.03f so I could make sure my NATO Fighters disc worked. While I was digging, I learned that there are at least five apparent variants of the CD.
257.09 KiB
418.2 KiB
255.25 KiB
274.7 KiB
133.1 KiB
Version 3 is the one I have (it's a darker grayish-blue disc with the "E" rating), so I know that's not it. That leaves versions 1, 2, 4 and 5. I know version 2 with the deeper blue disc and the "K-A" rating on it is the "CD-Rom Classics" disc, version 4 came in a big-box that was mostly black, and version 1 I believe was an international release in a light grayish-blue big box, but that doesn't help with this obviously. Does anyone have one of those other variants to try out and see what the installer has listed for the version number? I'd prefer to not just buy a bunch of them and hope for the best, so I thought I'd ask here in hopes that someone might be able to clarify this for me (and anyone else who gets Jane's ATF: NATO Fighters).
Thanks in advance 😀
Edit: I just found out about a fifth variant, so I added it.
Reply 2 of 12, by TheCoop
I knew I forgot to mention something.
I tried that patch yesterday, and it gives me an error ept0036... complaining about the old file not being found, finding one that has the same name, and then not updating because of the contents not matching.
All this on the file 1.LIB, if I recall.
Reply 3 of 12, by STX
That's unfortunate. Might the 1.03f patch be buried deep somewhere on the NATO Fighters disc?
Does your NATO disc have non-English writing on it? (I noticed that your disc was made in Europe and its text is in English. I wouldn't expect a British version to be different from the American version, but maybe you've discovered there was a unique British version that did not receive patches.)
Are you trying to mix DOS and Windows versions of ATF and NATO Fighters? (If the NATO Fighters disc has "GOLD" on it, then it's definitely for Windows.)
I did some more Google searching and only found more mirrors of that 1.14 patch.
EA FTP mirror at archive.org
Jane's ATF at archive.org
The Fighters Anthology Resource Center
Reply 4 of 12, by TheCoop
Mixing Windows and DOS? Nope. Both games install through DOSBox without issue and run in it just fine. And as far as languages go, the disc and small manual in the jewel case for ATF are both completely in English.
https://www.ebay.com/itm/175285033072?hash=it … YEAAOSwpcRiZwIF
That's a copy of ATF that I have. No Gold written anywhere, and most of the exe/bat files on the disc won't install/run outside of DOSBox because of them not being able to run on Windows 10. It also says ATFOEMBBC for the title when it's in the disc drive.
36.66 KiB
34.41 KiB
That's what my version of ATF NATO Fighters looks like. It also installs the DOS version and won't run outside of DOSBox for the same reason as above, and the title for the disc has 1.00f as part of the title when it's in the disc drive.
As for what's on the discs, ATF NATO Fighters doesn't have all that much. A trio of folders for various flight sticks, a read me that mentions nothing about a patch 1.03f, and the usual DOS files to be installed. For regular ATF, there are all sorts of folders for flight sticks, a Gateway folder that brings up the logo for EA's CD-Rom Classics menu (it has the only game-related files that run in Windows, and it makes me think that this is basically a repackaging of that version), folders for Adobe Acrobat (DOS and Windows) and the thick original manual in PDF form. Outside of that, it's the usual files to install the game in DOS.
I'm guessing this is a UK version based off of the disc title that comes up when it's in the drive. But the fact that someone was able to make an ISO of the 1.03f version means it's out there, or that a patch exists... somewhere. Add in that there are at least five versions of this game, and it's getting a bit stupid when it comes to finding the version ATF NATO Fighters wants. I just hope someone will be able to tell me which of the versions I posted is the need 1.03f version so I can grab a copy of it.
That said, thanks for helping to poke around with this thus far, STX.
Reply 5 of 12, by STX
I admit that I misread your first post. You wrote that you own ATF disc version 3, which was made in the USA. BBC in your disc's label ATFOEMBBC may stand for Best Buy Co., which sold PCs and PC games in the USA in 1999.
It's odd that your disc doesn't contain the fully patched DOS version of ATF because the 1.14 patch was available in 1997, and your disc has a 1999 copyright date. I have a hypothesis: In 1999, somebody at EA screwed up Best Buy's order for a pile of bargain bin titles by sending files for a pre-production version of ATF to the CD presser. If my hypothesis is true, then congratulations! You own a rare copy of ATF 1.00f that no customer was originally intended to get (which would explain why the ATF 1.14 patch doesn't work for you and there is no ATF 1.03f patch).
You are not the only person who has been unable to find a 1.03f patch for their ATF version 1.00f: https://gamefaqs.gamespot.com/pc/196546-atf-a … pgrade-to-v103f
That other person got ATF version 1.00f bundled with a CH joystick and also couldn't install NATO Fighters on top of it.
I've attached English, French and German NATO Fighters Cyrix CPU patches to this post. Tantalizingly, the German NATO Fighters patch is called "Patch 1.03F". If I were you, I would try the attached English NATO Fighters 1.01F patch on your ATF v1.00f installation, but I doubt that it will work because the patch instructions do not address a problem with the installation of NATO Fighters. It's worth a try though.
Reply 6 of 12, by TheCoop
Thanks for sticking around with this STX.
Well, I gave it a try, and the Cyrix patches won't install. Much like with the 1.14 patch, these Cyrix patches can't find the old file, finds one with the same name, then doesn't update because of the mismatch. But where the 1.14 patch was trying with the file 1.LIB, the patches you posted are trying with the file AF.EXE (yep, I tried all three).
This is ridiculous. An apparently unpatched game that can't be patched or have it's expansion installed because of an unupdated set of files that don't have a patch to update them.
Looks like I'll have to keep poking around and hoping that someone with one of the other disc versions shows up. I can't be the only owner of ATF on this site... I hope *lol*
Reply 7 of 12, by STX
Yeah, I'm sorry that we couldn't find a working patch. Maybe there's some music in the ATF Digital Music Update that will ease our sorrow.
https://archive.org/download/ATFDIG/ATF_DIG.EXE
Reply 8 of 12, by gerwin
I remember this issue: Trouble with installing NATO fighters over a certain ATF (DOS) base version. For that reason I bought the big box, which is a match with your version 4 CD image, as it has the letters "KA" on the top right. It has the volume label "ATF_1_03F", This big box edition allowed me to combine it with NATO fighters.
When I run "AF.EXE /N" it says the following while still in the DOS text mode:
"ADVANCED TACTICAL FIGHTERS (NATO FIGHTERS), v1.00F Release
In the Readme.txt it says: "All items in the ATF_114.EXE Patch are also included in NATO Fighters."
There was also a NATO Fighters patch v1.01F specifically for Cyrix 6x86 systems, as STX already wrote. But I am not using that by default.
This is the listing of a normal (midi music) installation from the "ATF_1_03F" CD, prior to merging NATO:
ATF.BAT      28-01-1996  12:17         346
AF.EXE 01-03-1996 19:21 1.307.792
AF.SYM 01-03-1996 19:21 56.592
READ.ME 29-02-1996 20:49 28.487
BRIEFING.TXT 25-02-1996 19:59 8.452
CHAT.TXT 19-02-1996 17:58 591
EXAMPLE.MT 22-02-1996 10:22 1.152
1.LIB 01-03-1996 19:27 11.019.290
2.LIB 01-03-1996 19:40 16.607.982
40.2D 01-03-1996 19:14 8.704
41.2D 01-03-1996 19:14 8.704
42.2D 01-03-1996 19:14 8.704
43.2D 01-03-1996 19:14 8.704
44.2D 01-03-1996 19:15 8.704
5.2D 01-03-1996 19:14 12.800
50.2D 01-03-1996 19:15 12.800
51.2D 01-03-1996 19:15 12.800
70.2D 01-03-1996 19:15 12.800
90.2D 01-03-1996 19:15 16.896
EGY.T2 01-03-1996 19:16 132.637
FRA.T2 01-03-1996 19:16 132.637
VLA.T2 01-03-1996 19:16 132.637
IREAL.XXX 01-03-1996 19:13 95
MREAL.XXX 01-03-1996 19:17 81
SREAL.XXX 01-03-1996 19:13 1.552
TIMEINT.XXX 01-03-1996 19:21 52
VREAL.XXX 01-03-1996 19:17 382
MODEM.DAT 26-02-1996 13:56 3.516
MODEMDB.TXT 29-02-1996 21:10 5.076
29 files 29.550.965 bytes
Reply 9 of 12, by TheCoop
AH HAAAAAAH! So it's the lighter "sky blue" disc that comes in the big mostly-black box. I had a hunch that was the one, especially when I found a German ISO of ATF earlier this evening that was also listed as 1.00f when installed (which made me doubt version #1 was the needed disc). Good to know.
Thanks for working with me to try and figure this out, STX, and a big BIG thanks to you gerwin for solving this issue for me. Now I'm off to find myself the needed copy. Hopefully this thread will be of use to anyone else who finds themselves in the spot I was in.
Reply 10 of 12, by gerwin
TheCoop wrote on 2022-07-28, 03:27:
That is the one. Attached is a picture that matches the box that I have, with the golden sticker on the left and again a "KA" logo on the bottom left. It comes with the spiral binder manual.
Glad I could help.
I posted the file list earlier, to determine the feasibility of making an unofficial v1.00 to v1.03 patch. Which would be easy in case just a few small files are involved. But since so few people care about this, it may not be worth the effort... Also, I now read in your initial post that you found the ATF v1.03 files already, but that you are trying to obtain a v1.03 physical copy regardless.
    25.05 KiB
Reply 11 of 12, by TheCoop
gerwin wrote on 2022-07-28, 15:36:
Glad I could help.
I don't know. An unofficial patch to make the 1.00f versions into 1.03f would be handy. There are really only a few copies of the 1.03f version on ebay (I think six), and someone might run into an issue where none are available. Plus, if they've already bought the CD-Rom Classics version or the jewel case version (like I did), they might not want to buy another copy. So if they search and find this thread, it would be helpful. Folks here have made patches to fix things like this in the past for other games, so I don't think the effort would be wasted 😀
Reply 12 of 12, by STX
On the technical side, we can't patch any files that are read from the CD at runtime. We would need to determine if there is a difference between the ATF 1.00f CD-stored files that are used at runtime and their ATF 1.03f counterparts. If there is a difference, then creating an unofficial patch wouldn't be worth the effort.
