GeneWars trouble with XP
First post, by NeoMoonlight
I seem to have the same problem as many people who have found this game and tried to run it in windows. The game works very well and everything but the colors are all just completely.... wrong.
I have a radeon 1300x and all the updated files. I have tried to use DOSBOX-6.5, but it keeps telling me I have some illegal read error. I have used the DOSBOX and config file from this thread
Genewars
I truely miss this game so I hope someone can help me out with these issues.
Reply 1 of 6, by NeoMoonlight
Fixed it with the Faqs and everything else. Thank you very much its so awesome to play this game again. Its just running slow and choppy on DOSbox so I'm off to find an answer to that one.
Reply 2 of 6, by wd
Rank DOSBox Author
DOSBox Author
Try dosbox 0.70.
Reply 3 of 6, by NeoMoonlight
I replaced the dos4gw with dos32a and it loads faster but the moment I try to push my mouse the game crashes..
Reply 4 of 6, by NeoMoonlight
Replaced the DOS32a with the old DOS4GW. I'm sure that I messed up somewhere and that is why the error happens. Everything is running fine, I have played up to the fourth or fifth level of the game, but the choppy-ness and the lag start to catch up, any ways I could fix this? I have played with the CPU cycles and skips and that does help but not nearly enough.
Thank you.
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
If you think you messed something up, why not re-install?
_________________
Reply 6 of 6, by NeoMoonlight
I did, and it runs, its just choppy and slow the farther I get into the game.
