Menzoberranzan voices
First post, by Changleska
I can get everything but voices to work in Menzoberranzan. (Using DOSBox.) I have voices in both Ravenloft games. Any ideas?
I'm Dan by the way. Great boards. Their how I got everything working.
Dan
Reply 1 of 8, by Myloch
Have you configured menzo to play sounds? Use sound_pm.exe to configure sound card. watch out for correct port,irq and dma dosbox values (see them in dosbox.conf)
Reply 2 of 8, by Changleska
Music and SFX work just not voices.
Dan
Reply 3 of 8, by Myloch
dunno... if it's a cdrom game, you've to mount the cd. search for dosbox documentation for explanations about that.
Reply 4 of 8, by Changleska
CD is mounted. Cinemas work. Dunno either.
Dan
Reply 5 of 8, by filipetolhuizen
Try selecting an alternative sound card for voices (if the setup program has the option to). DOS Box can also emulate a Gravis Ultrasound aside of Sound Blaster cards, which works great too.
Reply 6 of 8, by Changleska
I'm wrong. Turns out digital effects aren't working. Roland (for music) is working, but SB isn't . I've tried Pro, Regular and 16 with different IRQs and no luck.
Dan
Reply 7 of 8, by Myloch
In "sound_pm" menzo soundconfig utility:
try pro16 ---> use 1 ---> Sound blaster 16 ASP (220,7,1).
Please control that sound blaster is activated in doxbox.conf file.
Reply 8 of 8, by Changleska
Thanks for the help.
Dan
