There are a few options, but since those are Windows games, DOSBox wouldn't be one of those options.
VMWare Fusion allows you to run Windows in a virtual machine inside OS X. It works well for applications that I have tried such as Visio which does not have an OS X equivalent, but I haven't tried gaming using it. The latest version is supposed to have DirectX support but some features might not be fully implemented. A trial is available so you can always see it it will work, though you will need a copy of Windows too. There are also a couple others similar to this too, Parallels and Virtual Box, the latter being open source.
http://www.vmware.com/products/fusion/
BootCamp lets you run a dual boot system. It will automatically partition your hard drive and allow you to boot between OS X and Windows. It comes standard with Leopard. You will also need a copy of Windows with this method, as well as having to dedicate some hard drive space to the Windows partition.
There is also a program called Crossover Gaming that allows you to run Windows games on a Mac. It does not require a copy of Windows, but compatibility is less than the other methods. I believe it has a free trial as well.
http://www.codeweavers.com/products/cxgames/
Bootcamp would be the most compatible. My son has his MacBook Pro partitioned with it and can run even the latest games at playable speeds, though with the visuals and resolution turned down.
