First post, by DigitalFodder
hi, im a complete newbie to anything dos wise. I recently got toonstruck, i installed it. The sound didnt work and when detecting video in the setup it crashed. Tried to run it and i got a black screen. I found your program and installed it, i right clicked on it and ran with VDMS. Same output. Next i came across that vgafix, went to setup configured video and it works at 320x240 (or at least displaied the image) 😖 Sound still didn't work even when set to sound blaster 16 (Port:220 IRQ:7 DMA:5). Ran the toonstruck exe again and get a warning that it will be slow and bad IQ. [Y], still a black screen. 🙁 So i went to the config file in the toonstruck dir and change the 320x240 to 640x480. Now it says it may display in letter box mode, [Y] again and still a black screen! 😒
Can anyone guideme through getting thisgame to work in WidowsXP?
AMD Athlon 2400+
Abit NF7-S
1Gb PC2700
Onboard Sound (AC97)
GeForce 4 Ti4200
Much thanks to anyone that helps!
