First post, by Strider.BR
- Newbie
hiya, im trying to play constructor (from acclaim), and i have windows xp, i've done what this topic says: Constructor under WinXP
Constructor -DOS version (in winxp) […]
1. Download the univbe modified drivers from here: http://home.student.utwente.nl/r.muller...index.html (in the video problems section).
-Extract them and go to the \53a subfolder it created and copy the univbe.drv file from there to the game's /settings subfolder
2. Download the "VESA 2.0 patch for Windows NT/2000/XP (09/21/ 2002)" (nolfb.zip) from here: http://www.advsys.net/ken/build.htm
-Extract and place the files into the game's main folder.
3. You can either use notepad to create a start.bat file like this:
nolfb.com
game.exeAnd then use VDMSound on setsound.bat (to configure the sound) and then use the Launcher's default VDMS config. on start.bat to play.
OR
Use VDMSound on setsound.bat (to configure the sound) and then on game.exe to play (but use the Launcher's "custom configuration" setup option to add this line:
C:\full path to\NOLFB.COM
[Note: If you do it this way, you have to use the full path even if nolfb.com is in the same directory as the game. Also, using the VDMS "autoexec.bat" box has a tendency (on my machine anyways) to crash Explorer if you are DblClicking on a VDMS shortcut.]
...into the "advanced" "dos environment" "autoexec.bat" box.
4. If you receive an error about "networking" and/or experience a frozen mouse...
Open c:\windows\system32\autoexec.nt with notepad and change:
lh %SystemRoot%\system32\redir
to this:
REM lh %SystemRoot%\system32\redir
and then save.
[If you are actually using DOS networking for anything you will need to turn it back on later and this may or may not disable multiplayer in the game. VDMS's "enable low level networking" may also come into play (one way or the other) but I didn't think about that 'til now, so I don't know.]
-If I didn't forget anything the game should work fine.
Good Luck!
but i have a new problem now
the problem is:
when i run the "*.bat file", it runs but after some messages it says:
Error= Cannot allocate CD memory
could someone help me? i like this game a lot
my computer is:
athlon xp 2.4
512 ram
geforce fx 5200 128mb
[]'s
116808967
dniero@hotmail.com
