DOS command line support
First post, by simaobola
It takes some 20 years since i used MSDOS... i started with MSDOS 3.30, and growing since...
My request is that i can't remember HOW TO CROSS DIR command and COPY CON that i used to build an TEXT FILE WITH TREE AND FILES SIZE.
Presently i confess i can't remember how to cross both line commands...
Can you help me?
Thank you
Simon
Reply 1 of 3, by brotalnia
I am not sure i understand the question, but if you want to save results of dir command to text file you can do this:
dir >> test.txt
Reply 2 of 3, by dr_st
I don't think you need copy con for this. More likely a simple redirect of dir something >file will do.
Also, I am not sure I know of a way to get dir to display a tree. There is a separate program that does it, called, unsurprisingly, tree, but it shows no file sizes.
Reply 3 of 3, by Marek
"dir /s" goes through all sub-directories recursively. It is not a tree view, but it lists every file with date and size. If you also need hidden and system files, add "/a".
Also "help" is a very useful command. It even used to be hypertext, but it isn't anymore.
DOS-PC: DFI k6bv3+, Pentium 200mmx, 64 MB RAM, Terratec Maestro 32 sound card, Roland MT-32 + SC-155, Winner 2000 AVI 2MB, Voodoo 1, Win98SE
Windows PC: GigaByte GA-MA790GPT, Phenom II X4 905e, 12 GB RAM, M-Audio Delta 44, NVidia 1060 6 GB, Win7 pro x64
