First post, by ElBrunzy
Hello, I have been trying to make OMF2097 work on two computer but have never been able to make the sound work. No FX nor Music, but the game run smooth. I'm starting to think that I miss something else than memory and cards config. Here is the config:
  • machine 1: pentium1-200mmx, 128mb ram, freedos 7.1, fat32 udma CF of 16gb and a guspnp.
  • machine 2: pentium pro 200, 96mb ram, dos 6.22, fat 16 udma CF of 8gb and a gus classic.
I did play with the configuration of the card: baseport, dma, irq... The memory: different memory manager, way exceeding the base requirement of 2.5mb high and 540kb base. Notice that on the pentium1-200mmx when I try to run Jazz Jackrabbit, the screen startup say that I have to configure the soundcard even tho I did (and no file are read only). On OMF on the startup screen I have a something that look like a strange message on the lower of the startup screen with some garbage that look like ":j" is written, but I think it's random, maybe it's related to the no sound issue.
If anybody have a working config with a similar setup as mine (not dosbox), could you please tell me about the config.sys and autoexec.bat he use and the card configuration ? I'm in no way interested in using sbos or a soundblaster to play this game.
I used to be able to play that game with volume punching to the extreme the sfx and the incredible soundtrack. Now it just don't make sense playing on mute with my friend when we have the occasion 😢 ... Let's fix that for the next showdown ! 😏
Reply 1 of 6, by ElBrunzy
I just did some work on the machine 2 tonight and give OMF a try and it was working both in sb16 and gus classic mode! I think I understand why: I loaded EMS. I never have the reflex to load emm386 when I want to play a video game.
I'm not so sure about how to load EMS in freedos but I'll seek in that way to make the game sound work on it.
Reply 2 of 6, by gdjacobs
For EMS in FreeDOS, don't use the included EMM386 version. Get JEMM386 and JEMMEX (for use with UMBPCI). JEMM386 is essentially a drop in for EMM386 (with reduced memory footprint), except it does have compatibility issues with some TSRs like softmpu. I haven't tried aweutil or sbpci drivers, but they could have problems as well.
Reply 3 of 6, by ElBrunzy
Yes that's what I intend to try next. If my memory is good, I once try to use the emm386.exe that came with the ultrasound in an effort to test mega-em, but I dont remember clearly... I think maybe the odd version of emm386 that ship with megaem might be faulty.
From what I've read on the freedos website (http://help.fdos.org/en/hhstndrd/base/jemmex.htm) JEMMEX have it's own XMM. I think I might add 2 new option un my fdconfig.sys menu for JEMMEX and JEMM386. There is plenty of well documented options to play with too, they even explain why you might want to switch NOEMS on JEMM386 🙄 guess that's how you get XMS and something like 780kb of base...
I'm eager to give it a try tonight, I'll post my results here.
Reply 4 of 6, by gdjacobs
JEMMEX is intended to work with UMBPCI, so it lets UMBPCI handle UMB management. It doesn't manage XMM at all, just EMS. JEMM386 manages UMB in addition to EMS, the same as EMM386.
Reply 5 of 6, by ElBrunzy
I did many testing with jemmex, jemm386 and himemx with no results at all. With jemmex only I get a strange error message from omf209
For some reasons I had to go and change "PNP/PCI CONFIGURATION" in the bios and think there is maybe something here. I'll have to refresh my memory about "PNP OS Installed: yes/no", "Resources Controlled By: auto/manual" and "IRQ Sequence: "15,11,10,9,12,14,5,7,3,4", "9,10,11,5,7,4,3,12,15,14"".
do you think it worth anything to force the guspnp to a certain irq config and assign them to "legacy ISA" on the bios instead of "PCI/ISA PnP" ?
Funny thing when I did use jemmex.exe (and no himemx) OMF2097 did an audio click on startup and bring an odd error message on the screen. Unfortunately each characters where corrupted and I could not read them, they look like chars from copy protection of space quest 4. -- couldnt reproduce ...
about jemmex, I am thinking it dont need himemx as I've tested it and I got the idea reading this page http://help.fdos.org/en/hhstndrd/base/jemmex.htm
it is sayd:
JEMMEX is an Expanded Memory Manager which has an XMM already included.
and
JEMMEX most likely is the better choice than HIMEMX / JEMM386 because
it will need less DOS memory than an external XMM + JEMM386.
I did try to load JEMMEX and HIMEMX and it beep and complain that "Error: XMM already installed" then you got xms only. I did try JEMMEX NOEMS, you get many XMS ram and 751kb of base! ... but no sound in OMF2097 🙁
Everytime I run playmidi.exe and play a midi from ultrasnd to make sure the card work. I start to think that freedos is the problem here, what do you think gdjacobs ?
I could try to remove the 10/100 nic and the usb card and change the matrox g200 for something more standard. I think this would be the next step.
Reply 6 of 6, by ElBrunzy
YES ! Got it working ! With iweeprom 1.3 I've disable the sb emulation and gave two irq to the gus pnp. Then here is what I think made the trick, I ran prepgame in the omf directory, to program seem to have done some magic and now it's working. As the configuration file is not clear text I have no idea what prepgame did, I think I'll read more about that proggy.
