First post, by gulikoza
I sometimes help with the system administration on an elementary school. They have a lot of games and other programs running in dos. Recently we migrated the higher end machines to XP and there's of course problem with dos applications.
The most annoying thing is that these games generally work on windows XP but not on all machines. Some machines will just display blank screen. And I have no idea why. For instance, we have some computers with LCDs (not sure about exact config...some p4 celeron, integrated graphics) where everything works just fine. Then there are a bit older machines (again celeron, somewhere around 1.2GHz & crt monitor) which will just display blank screen when you start fullscreen dos aplication. If you exit with ESC, it will return back to windows. And just few days ago I installed another machine, where any dos application will just hang the system (again blank screen...esc and alt-tab not responding). I temporarily solved the problem by installing dosbox and running in an emulation, but the computers are somewhat slow and there are some other issues (like keyboard mapping). Any ideas what could be wrong? Refresh rates? Bios options? All computers are XP SP2.
Reply 2 of 12, by DosFreak
For the freezing problem:
Search in the c:\Windows or C:\winnt folder, within the files themselves for the text "ke386".
As for the fullscreen, black screen problem. What video modes do these programs use?
Make your games work offline
Reply 3 of 12, by gulikoza
No, no VDMSound (they don't need sound anyway in a classroom) just plain ol' xp cmd shell.
Dosfreak: what would these files be? Since I'm not there at the moment I searched on my machine and there are several files with 'ke386'...I'll try to get one on the apps Monday and see how it works on my machine and which video mode it uses...
Reply 4 of 12, by DosFreak
The files with ke386 in them in System32 or system32\drivers may freeze your DOS programs. If you have multiple ones just rename their extension and then reboot untiil you find which ones freeze your DOS programs.
As for the video issues read this thread, patch for WinXP/2000 monitor issues
The latest version with XP SP2 support is on the webpage on the last post in the thread.
Reply 5 of 12, by gulikoza
Thanks for the link. vga.sys fix looks promising. I'll try it and report back 😁
Reply 6 of 12, by gulikoza
I finally found the time to check the fix 🤣
Unfortunately vga.sys did not work 🙁. It was the same as before, black screen with cursor blinking in the top left corner. I'll attach one of the games here, I asked and they told me it was freeware. I think it uses 640x480 and it works quite slowly in dosbox. It also works fine on my computer nativly in XP so I really don't understand what could be the problem...
Reply 7 of 12, by eL_PuSHeR
Hmmm. Borland's BGI. Very old. I get the following error message both under native XP NTVDM and DOSBox.
Napaka v grafiki: Invalid device driver file (EGAVGA.BGI)
Izvajanje programa ustavljeno
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 12, by gulikoza
hmm...interesting.
Rough transtlation to english would be:
Graphics error. Invalid device driver file (EGAVGA.BGI)
Program terminated
Reply 9 of 12, by eL_PuSHeR
Replaced EGAVGA.BGI with a different one (from a game) and I am still getting the same error message. 😕
Intel i7 5960X
8 GB DDR4 (2100)
Reply 10 of 12, by eL_PuSHeR
Found out what the problem was and made a fix for the executable. BGI searching was set for C:\TP\BGI - Now it searches in the current directory. 😁
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 12, by gulikoza
That's even more strange...since I don't have C:\TP directory anywhere and the game is working fine on my system 🤣
I just checked the other non-working app (which is not free so I cannot post it here). Checking the executable it seems to be borland as well. But there are no *.bgi files in the directory, might be compiled in. Is there maybe newer version of Egavga.bgi available which might fix the problem??
Reply 12 of 12, by eL_PuSHeR
Try creating a bogus C:\TP\BGI folder and copy all .bgi file there. Check to see if the game runs properly that way.
Intel i7 5960X
8 GB DDR4 (2100)
