Zone 66 - What hardware does it *not* work on?
Getting old software/games running on older hardware.
Postby Thraka » 2017-1-11 @ 18:31
I tried testing Zone 66 on a Super Socket 7 with K6-III+ 400 but no matter what I did (disable caches, lower speed multiplier, etc) I couldn't get it to run. Anyone gotten it to run on a k6? I'm going to start swapping CPUs and jumpers but figured I would check here while I was at work :D
User avatar
Thraka
Re: Zone 66 - What hardware does it *not* work on?
Postby Jorpho » 2017-1-11 @ 20:42
Reportedly it is an unusually picky game due to its custom DOS extender. Unfortunately I am not sure what to tell you otherwise.
You might want to experiment with disabling himem.sys, as suggested by viewtopic.php?t=4401&p=32831 .
User avatar
Jorpho
Postby Thraka » 2017-1-12 @ 04:08
Yes it is picky :) I was using it as a test to see how compatible the K6-III+ with DOS stuff. I'm bypassing the config.sys and autoexec.bat on startup to remove any sort of setting that could interfere.
User avatar
Thraka
Postby gdjacobs » 2017-1-12 @ 07:31
Could it be similar to the Origin extender which ignored L1 cache enable/disable status?
User avatar
gdjacobs
Postby Blades » 2017-1-17 @ 06:45
I have a K6-2 450MHZ and it works just fine IF i use a Dos boot disk(7.1). Works fine ......As in, loads up goes to the menu and can play the game.
Now as far as sound goes, its hit or miss. I have a SB AWE32(jumper version) and sometimes it will pick it up with the /S command(sometimes without) and i will get some music(however its like some channels aren't playing the full sound track so it just plays the base part of the music)(not the sound card as it works just fine with all my other games). And sometimes i get no music and just digitized sound when firing the plane within the mission. Sometimes it plays the intro story and sometimes it skips right to the menu. Finicky game.
And this is testing using Original Shareware version and also my Registered version that I bought decades ago that had missions 3 and 4 on a floppy disk.
From what i remember after downloading this game for the first time from a BBS back in my 386 33MHZ days was that it was a pain in the butt to get working properly back then. And still holds true to this day. While it is a fun game, i don't find it worth all the headache to get it properly working as it seems to vary. Its a picky game. So I play it as is.
Blades
Postby Jorpho » 2017-1-17 @ 06:47
Blades wrote:it was a pain in the butt to get working properly back then. And still holds true to this day.
Well, not in DOSBox. Just sayin'.
User avatar
Jorpho
Postby Blades » 2017-1-20 @ 06:19
Ok, got me there. I was referring to actual DOS machines, as i think the OP was, not emulation.
Blades
Postby collector » 2017-1-20 @ 15:10
For help with games on old hardware ask in Marvin Software. viewforum.php?f=61
User avatar
collector
Postby 95DosBox » 2017-5-23 @ 21:05
Thraka wrote:I tried testing Zone 66 on a Super Socket 7 with K6-III+ 400 but no matter what I did (disable caches, lower speed multiplier, etc) I couldn't get it to run. Anyone gotten it to run on a k6? I'm going to start swapping CPUs and jumpers but figured I would check here while I was at work :D
This was the self bootable game correct?
I remember this ran fine on a 386. I can't recall if it worked on a 486 or Pentium 4.
User avatar
95DosBox
Postby leileilol » 2017-5-23 @ 21:51
I had it working on (66 FSB) Pentium IIs okay.
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
386DX vs SX isn't about a missing FPU
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
Old PCs aren't 'aesthetic'
User avatar
leileilol
Return to Software
Who is online
Users browsing this forum: No registered users and 0 guests
