First post, by expyscho
I recently installed WC3 and it's running, but it's choppy, and the music skips in and out. I downloaded nero drive to slow down my cdrom, but can anyone recommend what speed i should set the drive to? As far as the music does anyone know how i can fix the music so it doesn't constantly cut in and out. Thanks (I'm using dosbox .63, winXP, with an intel pentium 4, 2.4 ghz, And, i can't get the joystick to work, i downloaded a patch from wcnews.com, but, how do i apply it to get it too work? or is there another way to fix the joystick. Thanks.
