First post, by curt kendall
When I try to install Lemmings 2 with DOSBOX the install program loads and I am able to perform some of the set up but it hangs. It does installa new directory but no other files.
I am running windows xp sp2 on a p4 2ghz with 768mb ram, nvidia geforce fx5950ultra and soundblaster live.
I have tried changing cpu from normal to simple, turning on and off ems and xms. Lowered cycles to 1000 from 3000.
When I copy accross all the files from my old 486 dos machine it works under dosbox but does not get past level 1. Copy protection I think. So it is just running the install program from the original discs that I need to get past.
Any other suggestions?
