First post, by crazycrash
Hi,
can someone help me with an error occure during playing Imperium Galactica1?
The NTVDM CPU has encountered an illegal instruction.
CS:0000 IP:00c7 OP:f0 b8 10 a7 00 ..... > option , close or ignore
its no matter how i try to play ig1, with sound or without sound ,with latest patch or without ..... nothing works . I get the error after playing 1-2 minutes.
I try Dosbox but the Game and SOund was laggy on it !
plz help
cu crazy
Reply 1 of 6, by eL_PuSHeR
Hi, I editted your post title to get rid of the acronym.
Also, how did you configured DOSBox?
Did you read the GUIDES on this forum?
Did you use dynamic core?
Did you adjust cycles and/or frameskipping?
Please, let us know.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by crazycrash
i try the standart dosbox config and this one!
Try to change cycles, frameskip dont help me with lag
The only thing i dont try was dynamic core
[sdl]
fullscreen=true
fulldouble=false
fullfixed=false
fullwidth=0
fullheight=0
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
[dosbox]
language=
machine=vga
memsize=16
[render]
frameskip=0
snapdir=snaps
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=16000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
wavedir=waves
[midi]
mpu401=true
device=default
config=
[sblaster]
sblaster=true
base=220
irq=7
dma=5
sbrate=22050
# Richard - adlib used to be false
adlib=false
adlibrate=22050
adlibmode=adlib
cms=false
cmsrate=22050
[gus]
gus=false
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
# Richard - tandy and disney used to be true
tandy=false
tandyrate=22050
disney=false
[bios]
# Nothing to setup yet!
[dos]
xms=true
ems=true
[modem]
modem=true
comport=2
listenport=23
[autoexec]
mount C "C:\spiele\IMPERIUM"
mount E "E:\" -t cdrom -ioctl
C:
Reply 3 of 6, by eL_PuSHeR
You should definitely give dynamic core a try.
core=dynamic
cycles=25000
Try testing for yourself.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 6, by crazycrash
woohooohoooo
pusher i luv u
ok with dynamic core and 25000 cycles the game works n1 but the soundquality is lower then with vdm!
But my mainproblem was ntvdm error. Have u solution ged rid of the problem?
Reply 5 of 6, by eL_PuSHeR
I'm afraid not, but now that you managed to get it running reasonably well, you could keep reading information about how tweaking up DOSBox. You can also wait a little until next version is released (0.64). It will sure have a lot of bug fixes.
Intel i7 5960X
8 GB DDR4 (2100)
