First post, by nostalgia
Hi. I'm new to the forums, and i first like to say that DOSbox works great for me, most games that didnt support music or sound suddenly did when ran through DOSbox. now onto the problem...
I've been tryin to install a game, called BLUEFORCE. as you may or may not know, the setup file was programed to have floppy disks that came with it when purchased inserted into the floppy drive. i no longer have the disks, but i have all the files from the disks backed up. what i normally could do is copy the data to a floppy disks (8 or 9 to be exact) and insert them at time of installation. However my floppy drive is shot and attempts to get it to work have failed... i believe you must first install this game before you can play it because when i ran BLUE.exe (the game file itself) through DOSbox it just crashed immediatley with no indication of the error that caused, though i believe its because the game was not properly installed. so heres the big question
Any way i can install the game through DOSBOX with the data that came from the floppy disks but without being able to use floppys cause the drive is shot?
