First post, by kadi500
Tomb Raider Running
When I try to install the game - the following error shows up:
DOS/4GW Protected Mode Run-time  Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
DOS/4GW error (2001): exception 0Dh (general protection fault) at 21F:00006F12
TSF32: prev_tsf32 5298
SS 22F DS 22F ES 27F FS 0 GS 0
EAX 0 EBX 22F ECX 0 EDX 0
ESI 120 EDI 58A0 EBP 5247 ESP 4448
CS:IP 21F:00006F12 ID 0D COD 5C30 FLG 13246
CS= 21F, USE16, byte granular, limit 914F, base 29EF790, acc FB
SS= 22F, USE16, byte granular, limit 489F, base 29F88F0, acc F3
DS= 22F, USE16, byte granular, limit 489F, base 29F88F0, acc F3
ES= 27F, USE16, byte granular, limit 7CFF, base 2A21B90, acc F3
FS= 0, USE16, byte granular, limit 0, base 2A21B90, acc 0
GS= 0, USE16, byte granular, limit 0, base 2A21B90, acc 0
CR0: unavailable
TOMB.exe also shows similar error. The game works well with DoSBox, but when using DosBOX, I cannot use glidos features, can I?
I remember I was able to play this game under XP, but I suppose that was before service pack 2... or before purchasing HT processor... or before ATI Radeon X800... I really don't know...
Could you help?
My config:
Microsoft Windows XP Professional Service Pack 2
6.0.2900.2180 (IE 6.0 SP2)
4.09.00.0904 (DirectX 9.0c)
Intel Pentium 4, 3000 MHz (15 x 200)
MSI 865PE Neo2-PS (MS-6728 v2.0) (5 PCI, 1 AGP, 4 DDR DIMM, Audio)
Intel Springdale i865PE
1024 MB (PC3200 DDR SDRAM)
AMI (09/29/04)
RADEON X800 PRO (256 MB)
Creative SB0092 Audigy Player Sound Card
Realtek ALC655 @ Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
Maxtor 6Y120P0 (120 GB, 7200 RPM, Ultra-ATA/133)
ST3120026A (120 GB, 7200 RPM, Ultra-ATA/100)
ST3200822AS (200 GB, 7200 RPM, SATA)
ST3250823AS (250 GB, 7200 RPM, SATA)
ST3250823A (250 GB, 7200 RPM, Ultra-ATA/100)
LITE-ON DVDRW SOHW-1693S (DVD+R9:4x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:48x/24x/48x DVD+RW/DVD-RW)
Reply 2 of 4, by kadi500
Yes, I did with previously installed game, and even with a game installed with DosBox, but it it ends with the same error - see attachment.
    9.05 KiB
