Crusade Error
First post, by noobstar
Hi,
I hope you understand my english because I'm a german user.
I want to play an old DOS-Game called Crusade. The installation worked but when iÍ want kto play it there is the Error:
VDFS Error: This Programm needs MSCDEX or NWCDEX so that it can Read the CD-Rom.
Program abortet
So my Question is:
What is wrong - can I install this "MSCDEX in DOSBox?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you need to mount your cdrom of the game using the -t cdrom flag
type in dosbox
intro cdrom
for more information
Water flows down the stream
Reply 2 of 3, by avatar_58
Did you mount the CD properly?
(Where D: is the letter of your drive)
mount D: D:\ - t cdrom
EDIT - People keep getting here first 😅 I'm getting slow.
Reply 3 of 3, by butamigiu
hi all...
I just jump on this abandonned topic, because I've got the same problem for the same game...
I checked with all the solution I found, but none is working. To be more specific: dosbox tell me: "mscdex installed" when I mount the cd-rom drive as a cd drive, when it is in a subdirectory, it tells me it is only partialy suported, but in both case, the game continue to tell me the same error msg.
Any idea plz?
PS: I've got dosbox 0.65 on windows xp, and I tried also the label and "iosomething" stuff...
