First post, by Aspie_Boi
Has anyone had any success with this title? (called Lemmings Chronicles in the US I'm told).
I've tried running it under native NT dos box, with VDMSound and in Dosbox 0.56.
In dosbox the install program runs but when I try to load the game dosbox crashes with an 'unsupported feature' error (I'm not sure which feature it is refering to (as I'm sure the game isn't a protected mode title).
Under Native NT command prompt and also with VDMSound the game installs... (I have to use a slow down app to get past the run time 200 error, and enable Expanded memory) but when I try and load it, the PC switches to full screen mode and just sits there with a black screen. I've tried running it with sound / music disabled from the setup program but that changes nothing.
**Note: The game's setup program also offers standard and 640x480 screen resolutions so perhaps it needs a VESA driver (but there's no mention of it on the box).
I don't think there's any point running it from within VPC as I have an old Pentium PC which I tried it with (using DOS 7.0 with genuine DOS CD-ROM, Mouse & SB drivers) and the same thing happened.
Has anyone had any luck with this game? or have any more ideas I can try? (I'm running Windows XP Pro SP1 btw)
