Reply 20 of 23, by elianda
- l33t
My DOS PC System is configured this way:
My DOS Games PC
I had huge problem if I switched the Bios to PnP OS - No.
Its was not a problem of assigning PCI Cards, but there aren't enough resources that the Bios can configure each card. So it skips some completely.
For this configuration I put the GUS on 240,7,7,7,7. So this is reserved for non PnP in Bios.
This leaves IRQ 3,5,9,11 and DMA 0,1,3,5.
So now the problem starts:
SB 32 would be fine on IRQ 5, DMA 1 and another DMA for 16 Bit (3), Port 220.
The Crystal 4232 on the Maxi Sound needs also be initialized to get access to the Dream DSP that is attached as external CD Device to the CS4232. It's some kind of internal General Midi with Port/IRQ.
The CS4232 has SB Pro, WSS and FM Synthesis Resources.
So the SB Pro part needs to be put to IRQ 3, DMA 0, Port 260. WSS is no problem, but FM Synthesis gives a conflict you cannot prevent, cause you cannot change the Port. So one card will be visible from software side and you need to make sure the PnP config utility wont abort on this.
Whats left: The General Midi Part
For the Crystal CS4232 its not needed - disable (hardware port)
For the Dream9407 DSP it needs to be enabled with the Crystal to 330/9.
SB 32 PnP has no GM hardware compatibility for the internal wavetable, external port can be disabled.
GUS external GM Port can be disabled too or put to 300.
The same applies to Joystick ports. enable on one card, disable on the others.
If you let all of this do automatically it wont work because the application trys to initialize first all stuff for one card before it goes to the next one.
A nice side effect on this configuration is: The Dream9407 is at 330 in hardware, but if you decide to use the GUS as GM device you can load MegaEM to emulate at 330. It will say that there is already a hardware device, but it works. It catches all Port accesses before they reach the Dream. So you can switch without changing any game configuration.
