11th hour
First post, by Adam
Well I'm having troubles with this game...
I have the win32 direct x thing and It plays but the sound is messed up.
I try it in dosbox and the sound works perfect but it runs slow and very annoying. Does anyone know how to get this to work?
and If I run it with VDMsound I get this error
check4MSCDEX: ---------------------------------------------------------
check4MSCDEX: data for drive A: follows
check4MSCDEX: door is closed and locked
check4MSCDEX: Supports only cooked reading
check4MSCDEX: Read only
check4MSCDEX: Data read only
check4MSCDEX: No interleaving
check4MSCDEX: prefetching is not supported
check4MSCDEX: No audio channel manipulation
check4MSCDEX: Supports HSG addressing mode
and if I run the directx patch with VDMsound it doesn't do anything
Reply 1 of 1, by eL_PuSHeR
Have you searched the forum yet? I think 11th Hour has been discussed several times.
Are you using dynamic core in DOSBox?
Have you read the guides on this forum?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
