The disc is an older version. There is NO "Install.EXE" on the disc whatsoever. The only ".EXE" file that is on there is "Setup.EXE" which, when ran through DOS or just normally double clicked, it gives an error message saying, "Cannot find Shell.DLL". It also says (after you click OK) "The second part of Sierra's Setup program was unable to execute. Please try running_SETUP.EXE in your TEMP directory. If this fails, contact Sierra technical support for assistance."
Soooo... I also have an option to create a boot disk, which in this case, I don't think is the problem seeing as how this computer has a gig of memory and is running a 3.14GHz P4 as it's processor.
The other few files that are on the CD are.... 2 folders, AVI and ENGLISH; MKGROUP, RESOURCE, SCIDLL.DLL, SIERRAW, 2 help files, and some other random RESOURCE files that are all on there.
