Ringworld 2: Return to Ringworld sound
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby Snover » 2002-8-06 @ 12:24
I'm not sure if this is something that occurs with all of the old DOS Tsunami games (some of the best there are), but whenever a sound effect is not playing, independent of speech or movie audio, there is loud clicking. This isn't dependent on VDMSound: SoundFX exhibits the same behaviour.
Ideas on what's causing this, and possible workarounds or solutions?
Snover
Re: Ringworld 2: Return to Ringworld sound
Postby vladr » 2002-8-16 @ 15:45
Snover wrote:I'm not sure if this is something that occurs with all of the old DOS Tsunami games (some of the best there are), but whenever a sound effect is not playing, independent of speech or movie audio, there is loud clicking. This isn't dependent on VDMSound: SoundFX exhibits the same behaviour.
DC offset. Use VDMSound to dump the audio to file, and open the .wav in an editor to see what the heck's going on. You'll probably see a sharp drop to 0 or something at the end of every sample. Reducing treble to minimum may alleviate the problem.
V.
User avatar
vladr
Postby Snover » 2002-8-16 @ 21:38
Vlad, can you add JIT DC correction? I'll try your suggestion and see what I come up with. (Damn these old games and their propietary data formats!)
Snover
Return to DOS
Who is online
Users browsing this forum: No registered users and 2 guests
