Originally posted by Soniclen I don't have the original CD disk, so I'll go to creative website,...
Ugh...not good. Am I understanding you correctly that this is an "onboard" audio chipset instead of a plug-in card? If so, I have to give you fair warning that it will probably be a constant pain (not very compatible).
I had already looked at Problem Child when I sent the original message, so unfortunately none of that worked.
Unfortunate. Makes matters worse that Creative doesn't have DOS drivers for the PCI 128 for download.
Try going here:
http://www.softlab.ntua.gr/~sivann/software.php
Scroll down to "DOS drivers for SoundBlaster PC128 cards" and try following his directions. Pay special attention to his BIOS instruction. Note that this is a "hack". It wasn't really meant to work like this. Good luck.
Do you know of any command in DOS (or win) where you can check the compatability/working order of both your CD Rom and Soundcard?
No, I know of no compatibility test for sound cards, but you can try running VGA Utils for your video card:
Try running these VgaUtils:
http://www.simtel.net/pub/dl/51867.html
These test basic DOS graphic video modes.
You might also try running VBETEST.EXE from UniVBE v6.7:
http://www.scitechsoft.com/products/enterpris … ree_titles.html
It allows you to individually test SVGA video modes. When you start up VBETEST, it should come up with text like this:
OEM string: IBM SVGA BIOS, (C) 1993 International Business Machines
Version: VBE 1.2 with 4096 Kb memory […]
Select test to perform:
[0] - Interactive Tests
[Q] - Quit
You then select zero for Interactive tests:
Select color mode to test:
[0] - 4 bits per pixel modes [3] - 16 bits per pixel modes
[1] - 8 bits per pixel modes [4] - 24 bits per pixel modes
[2] - 15 bits per pixel modes [5] - 32 bits per pixel modes
[6] - Text modes
[Q] - Quit
Then select 1 for 8 bits per pixel modes (it's also a good idea to test for 16 bits and 24 bits later):
Which 8 bit video mode to test:
[0] - 640x400x8, 1 page, Banked+Linear
[1] - 640x480x8, 1 page, Banked+Linear
[2] - 800x600x8, 1 page, Banked+Linear
[3] - 1024x768x8, 1 page, Banked+Linear
Test modes like these to see what kind of response you get. The 640x480x8 mode is the most important as it's the most commonly used.
