First post, by StickByDos
Are there some way to play network dos games between dosbox and real dos ?
real ipx on dosbox:
No change on dos machines but need to install ipx protocol on XP, which add some problems and can't work with internet.
Can be possible for lan-parties but I think the 1st hour would be spend explicating how to set up ipx on xp and on dosbox.
udp tunnel under dos:
Nothing to change on XP and doxbox, can work with internet.
It needs a tsr which intercept ipx calls and redirect them throught a resident packet driver.
I think it is possible as I've already connected my 386sx to internet using arachne, it was slow to display pages but it worked.
Type win to loose the power of your computer !
