First post, by DarKain53
When I had Windows 2000 I used VDMSound to hear the better sounds in the older games I downloaded. But now, with Windows 98, I can't use VDMSound anymore. Is there another program I could use to do this, or is there a way I could do it myself?
Reply 1 of 1, by HunterZ
If you look in the VDMSound areas of the forum, you'll see that there's an experimental Win9x version. Try that (or maybe even consider going back to 2000/XP?)
