First post, by unit
i've trolled thru the boards here looking for an answer, but found none.. hopefully somebody can help?
i'm using flopper to run an img called WIZARDRY 1 (proving grounds of the mad overlord) i can access the master disk, which lets me into the game menu, but then i have to (somehow) change to the scenario disk and when i do this, my PC resets.. what am i doing wrong? how do i swap the img over?
oh yeh - sorry for sounding like a newb.. i kept at it untill i got the master disk working, but i can't seem to get past this disk changing hurdle??
Reply 1 of 2, by unit
didn't figure it out.. but will continue to tinker..
i used img2dsk utility to convert both files to a disk, it worked! and i am now able to use these disks to play the game..
how to
format 2 disks as 720k
use the img2dsk utility to convert each file (wizmast and wizscen) onto a floppy
done!
