First post, by Sladi
Hi!
As suggested I opened a new thread. 😀
I don't know how to enable Midi music in Larry games (if they're supported). I bought a collection CD and it's got the enhanced version of Larry1. There is no Midi mentioned in the manuals.
Also when installing Ultima7 it says not enough space available on c. I think I could get it to install once though. I can play fine but maybe someone knows what's the problem.
I use Dosbox 0.72.
Regards,
Sladi
Reply 1 of 8, by Kreshna Aryaguna Nurzaman
Sladi wrote:
Hi!
What happened when you installed the program? The Larry installer should ask you to select the sound card for the game; does the installer have separate "select your sound card" for music and sound?
Kreshna Aryaguna Nurzaman.
Reply 2 of 8, by Sladi
I just tried installing again. The installer doesn't ask about my card. I saw some lines about choosing a soundcard in sierra.ini but this never comes up.
Also when I try running the games using the Sierra launcher none will start. The included Dosbox 0.63 starts but then it disappears. When overwriting it with version 0.72 they start.
Reply 3 of 8, by simonecuttlefish
Wild guess, but is there a setsound.exe, or setup.exe, ir install.exe (or something similar) in Larry's install folder? Some old games used to have a seperate post install setup routine for configuring sound.
Reply 4 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
As for installing Ultima7 see this guide I wrote for Exult (and the sub section on hwo to install it on Dosbox)
http://exult.sourceforge.net/docs.php#dosbox_floppy
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 8, by Sladi
Danke! 😀 I did that since I already tried Exult. I posted there about the scaler config.
I figured maybe there is some explanation since I had been able to install it fine before. It seems some dosbox setting is te culprit.
I guess you sold the MT-32 recently in Vienna? Unfortunately I missed the end of the auction. 😜
Regards,
Sladi
Reply 6 of 8, by Dominus
DOSBox Moderator
Nope, I just happened to stumble over it and I think Qbix is not disappointed that you missed the end of the auction 😀
Reply 7 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
for those collections CD with larry and such there is a patch that upgrades it a lot.
look at the forums of vu (patch created by collector)
Water flows down the stream
Reply 8 of 8, by Sladi
No, they took these out. But the patch by Collector adds them again.
Thank you very much Qbix! It works now. 😁
P.S.:
I love Dosbox! When upgrading my PC I never thought about what happens to old games and gave the old computer away.
Now I can finish my games. 😀
