First post, by Megatron1983
I bought the CD Version of System Shock 1 from a friend and set it up properly on my XP Home SP1 Machine. The game starts perfectly and runs smooth as well, the only problem is that I dont have any sound even though the Sound Emulation is active and loaded properly. This happens during the Intro AND the game!
I have VDMSOUND latest version installed and already played around with the settings a little, however it does not work.
Do you maybe have any reference config info for using the program with nForce boards using the onboard sound?
The problem accours on nForce 1 as well my nForce 2 with Soundstorm board by the way.
Which device should I use? Primary Soundriver? nForce Audio?
What IRQ? etc.
Thanks in advance for any help,
Helmi
