First post, by Romen
Yeah, i know the people here did not make this, but i was wondering...
No iret or NULL interrupt vectors were found from vector 0x60 to 0x66.
Handler will wedge into interrupt 0x66.
What does this error mean? I get it when i first load One Must Fall 2097.. Other than that, it runs it great...
I noticed that it only uses about 45% max of my CPU.. hmm
I run the following system:
Epox-8RDA3+ Motherboard with nForce 2 chipset
AMD Athlon XP 2400+ @ 2.333ghz (standard is 2.0ghz)
768mb PC 2700 RAM
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
Doesn't matter. it's fixed though. it happened because the memory of dosbox is filled with CD CD instead of 00 00
so the program thought a handler was installed.
about the 45 % thingie => great you can run the game at higher speed if you want.
ctrl-F12 will do that for you.
Water flows down the stream
