First post, by Greeny
Using Mok modified .exe I had previously got SS working fine. However I suffered a random crash when I hadn't saved for ages and stopped playing for a while. Now it no longer works: The screen goes black for half a second then goes back to the desktop.
I've tried a fresh install, with and without the modified .exe, tried running NOLFB.com (from full-screen command prompt) and DOS4GW.exe (various versions)
the .bat file looks like:
@echo off
nolfb.com
dos4gw.exe cdshock.exe
I've tried disabling sound and trying various combinations of the above but I can't even get to the intro/main menu.
System specs:
XP Pro
AMD XP 2100
512 MB RAM
OK so what should I try next
