First post, by Marko
so far I tested a lot of my win games for compatibility with xp and the result is not so bad but now I'm coming to the dos section and as you might guess the problem is the sound and the memory.
I have a PCI sound card (sb16 pci) and i made a dos boot disk. Everything is fine except the sound. Because I have a pci card i need to install an sb emulator (sbinit.com) this emulator only installs when emm memory is present. The only way i found to enable emm is by installing emm386.....now sound is fine BUT some games running in dpmi mode (using dos4/gw) are not running with emm provided by emm386.
I have tried to install qemm ver.8 to avoid this problem but qemm causes other mistakes.....
so here's my question: are there any freeware memory managers which provide dpmi support or are there any sb emulators which doesn't need emm386 or are there any other ways to avoid these problems?
Games not running the way I tried (so far): psychic detective and creature shock.
