XIV. Using dgVoodooSetup (Command Line, advanced)
If command line of dgVoodooSetup is not empty, GUI interface does not pop up,
information for setup operations are taken from the command line. No any feedback
on the console. (Damn, an application can't be both a GUI and Console application
under Windows, at least not in an easy way.)
This is useful for using the setup in command line scripts.
You can model the GUI workflow, which is usually the following:
- configuration is loaded from either the wrapper file (glide2x.dll, glide.dll),
or from an exported config file
- some config changes are applied if needed
- configuration is either saved in the wrapper file, or exported to external config
file, or both
Command line options:
dgVoodooSetup [wrapperfile] [/opt1] ... [/optn]
