First post, by Sheppi
I have the CD version of this game.
I´ve tried to run it with vmds and with the launch pad also, but the game refuses to run cause it can´t find a vesa driver, even though i´ve enabled basic vesa support.
Is there any way of getting this baby running under 2k ?
Thx four your help.
Sheppi
My machine:
Mainboard MSI 6380, Athlon XP 1600+, ASUS Gf3-Ti200/64MB,
512 MB DDR ram, Win2k SP2
Reply 1 of 7, by vladr
*Disable* basic VESA support, then press Alt+Enter quickly every time you see the VDMSound license on the screen in the DOS box. Windows' VESA support is so much crap that sometimes you actually have to go full-screen by pressing Alt+Enter in order for it to work (don't ask me why because I don't have the slightest idea).
V.
Reply 3 of 7, by DosFreak
Why use command.com? In NT it's just slower and I've never seen it increase compatibility over NTVDM. It may work for slowing down programs.....mabye...but it would be REALLY slow.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 7, by DosFreak
No diff.
Reply 6 of 7, by vladr
VLP files don't use either. They just get converted (at runtime) into a .pif, a config.nt, an autoexec.nt, a VDMS.INI and the .pif is "run" (whatever does Windows do behind the scenes with that). In any case, spawning a command.com "manually" (which you can easily do with vlp files anyway -- just specify %SYSTEMROOT%\system32\command.com as the excutable and "/c mygame.exe bla bla" as the arguments) will only give you two instances of command.com in memory (you can check).
V.
