Dos 6 conventional memory tricks
Getting old software/games running on older hardware.
Re: Dos 6 conventional memory tricks
Postby Jorpho » 2013-10-07 @ 02:58
valnar wrote:but for those who don't know, FreeDOS has had compatibility problems its entire existence.
It has had an exceptionally long existence, and I would have thought some of those compatibility problems would be diminished by now. Can you go into more detail?
User avatar
Jorpho
Postby PhaytalError » 2013-10-07 @ 15:14
While it's rare and total random some games simply don't run properly with FreeDOS... sometimes they glitch out, slow down, or have quirks that make them unplayable. Windows 3.1 / Windows 3.11 WFWG absolutely won't run in 386 mode and this has been known for years which the FreeDOS developers have not fixed, etc even though users have requested it for many years to be fixed.
For a DOS that's been around since 1994, you'd think they would have 100% MS-DOS compatability by now (it's been almost 20 years in development).
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
User avatar
PhaytalError
Postby Jorpho » 2013-10-07 @ 15:25
PhaytalError wrote:While it's rare and total random some games simply don't run properly with FreeDOS... sometimes they glitch out, slow down, or have quirks that make them unplayable.
But which ones, specifically?
There seems to be a lot of conflicting information about that. Have you tried it yourself?
I can definitely agree that their documentation is a catastrophe, so if there's actually a place that tracks these things unambiguously, that would be very interesting.
User avatar
Jorpho
Postby valnar » 2013-10-07 @ 17:02
Jorpho, I did not keep a log of games that did not work. I guess I'm not that scientific. But after enough problems, I saw no need to continue playing with something so unstable. I do recall it wouldn't even work in VMware (or was it VirtualPC?) without crashing the VM. I think I have a thread on that here in Vogons. Then there is issue with certain aftermarket memory managers...
I guess the better question for you is, why do you want it to work so badly? It's easy to pick up a copy of MSDOS 6.22 from eBay for $10.
valnar
Postby Jorpho » 2013-10-07 @ 17:51
I'm curious more than anything. As has been said, it's been almost 20 years now; if it's really that bad, what could the problems be?
Besides, MS-DOS has its own inconvenient limitations, and not everyone is inclined to go buy MS-DOS on eBay. It's not like it will be available there forever anyway.
User avatar
Jorpho
Postby jwt27 » 2013-10-08 @ 17:38
I haven't found any games that are completely incompatible with the FreeDOS kernel. Some game are incompatible with certain memory managers, that's why I use a config.sys menu to switch between UMBPCI+XMGR and JemmEx. Just about anything will run with either one or the other. If configured correctly, FreeDOS is a very fast and quite stable OS, requiring very little memory (I have 627k base memory free with everything loaded, see the link in my sig.)
One thing I noticed which I think may be caused by the FreeDOS kernel itself is this bug in adtrack2.
WANTED - Manuals/drivers for:
  • Tecmar Graphics Master
  • Paradise Autoswitch EGA 350 (EGA1A)
User avatar
jwt27
Postby Samir » 2013-11-14 @ 13:44
I'm new here, but I ooohhh so remember the days of manually tweaking all my autoexecs and configs for conventional memory.
The best thing I found was to use a program that I don't remember anymore to actually 'look' at all my memory 1mb and below. You could see which regions had a bios in it, which were empty, which were free, which were allocated, but actually had nothing in them.
Then I'd map those regions and figure out how much free space I had in each region. Then I'd take all my drivers and figure out which one should fit where. Then I'd program them in into the autoexec and config and test. If there's a problem, readjust and test again.
It would usually take a whole day to do this, but in the end, I'd have everything I want running, including smartdrive, network drivers, and niceities like doskey. :)
I know I've still got those carfully configured files still sitting on my old systems. Too bad I haven't booted some of them in a decade now. :(
Samir
Postby schlang » 2013-11-26 @ 11:07
DonutKing wrote:
Even if you don't want to use dosmax, I got instantly positive results from simply adding these switches to emm386:
DEVICEHIGH=C:\DOS\EMM386.EXE AUTO RAM M3 A=64 H=128 D=256 HIGHSCAN X=B800-C7FF I=C800-EFFF I=B000-B7FF NOTR
just a note, I remember that some games crash when you include specific ranges using the I=XXXX parameter
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
User avatar
schlang
Postby Samir » 2013-11-27 @ 01:07
And this would probably be because they think that those regions aren't used, like on the original PC and XT and try to use them directly. Easy enough fix though by just having a menu setup in DOS to load a different config. Or you can just F8? (F5?) your way through every line item.
Samir
Postby schlang » 2013-11-27 @ 01:13
problem is that you just have to guess WHY the game crashed - it does not tell you "hey you are stealing blocks B000-CFFF" ;)
User avatar
schlang
Postby Samir » 2013-11-27 @ 01:55
schlang wrote:problem is that you just have to guess WHY the game crashed - it does not tell you "hey you are stealing blocks B000-CFFF" ;)
True, but the first thing I always did when I had a consistent crash on something like that was to boot up to a bare DOS with very minimal settings and try it. Usually there was enough conventional. If it crashed there, then it probably wasn't memory related. If it worked, then I'd just build a config for it.
Samir
Postby DonutKing » 2013-11-27 @ 03:57
It's not so much the I= parameter that is causing the crash - its that you are using it to include memory ranges that are already used.
You can use MSD.EXE or a similar program to view the memory map and identify free upper memory ranges.
I still use a similar EMM386 config and I haven't run into any games that don't work (except Ultima 7 or Zone 66 which will never run with EMM386 anyway).
User avatar
DonutKing
Postby Samir » 2013-11-27 @ 14:48
DonutKing wrote:It's not so much the I= parameter that is causing the crash - its that you are using it to include memory ranges that are already used.
But even sometimes when these ranges appear free, programs will directly address them, bypassing any memory managers--then you have a mysterious crash.
I forgot about MSD! That's a pretty useful program to examine those ranges, although whatever I was using (which I can't remember), was more detailed and helped me find more ranges than MSD.
Samir
Postby Jorpho » 2013-11-27 @ 16:41
Microsoft explicitly recommends the use of E000-EFFF and B000-B7FF (provided you're not using an IBM PS/2 and a monochrome monitor) at http://support.microsoft.com/KB/77083 . Of course, there's probably some game out there whose developer just assumed that those ranges were safe since no one would bother configuring EMM386 to use them.
User avatar
Jorpho
Postby Samir » 2013-11-27 @ 18:38
Jorpho wrote:Microsoft explicitly recommends the use of E000-EFFF and B000-B7FF (provided you're not using an IBM PS/2 and a monochrome monitor) at http://support.microsoft.com/KB/77083 . Of course, there's probably some game out there whose developer just assumed that those ranges were safe since no one would bother configuring EMM386 to use them.
I remember those recommendations! I remember one of them causing havoc when they were included where a bios was. :lol:
A lot of times, I was able to use parts of Cxxx and even part of the Bxxx range after the recommended block. You basically would tiptoe around any BIOS's that loaded in there and include the rest. I remember where on some systems, I had a ton of high memory, like 200k. :cool:
Samir
Postby DonutKing » 2013-11-27 @ 20:37
Do you have an example of such a program? Ive not come across one. Win 3.11 can be finicky with memory ranges but it will just throw an error when you start it and you can set EMMExclude in system.ini to work around it.
User avatar
DonutKing
Postby Samir » 2013-11-27 @ 21:03
I don't know of one off the top of my head, but I remember running across this with applications when I was building my autoexec.bat and config.sys back in the day.
It would go like this--everything works fine, awesome, try out all the programs, oops xxxx is crashing, hmm...try previous set of includes that doesn't include xxxx range, everything works fine, oh well.
I never really ran into an issue with Win 3.1 (not sure if 3.11 would have done things too much differently like WFW did). The only time I did in Win 3.1 was when I saw some empty (FF) ranges inside two blocks of a BIOS and included it. Under certain conditions, Win 3.1 would have a problem with that.
Samir
Postby gnuuser » 2014-3-27 @ 13:31
im sure its on here somewhere but if I remember correctly there is a specific order in which the commands in the autoexec .bat and config.sys should be that makes a lot of difference in how fast the system will boot up and run.
Ill look through my old files and see if i can find it.
User avatar
gnuuser
Postby schlang » 2014-10-01 @ 23:18
I keep getting new email notifications to this thread, but there isn't any new post?
User avatar
schlang
Postby Jorpho » 2014-10-03 @ 16:01
There may be someone spamming the thread (either with advertising or with idiocy) whose posts are being deleted before you can see them.
User avatar
Jorpho
PreviousNext
Return to Software
Who is online
Users browsing this forum: Errius and 3 guests
