First post, by chris_clarke
I've recently purchased a copy of Ultima Underworld 1 and 2 on CD and i'm having major problems with it.
I'm running Windows 2000 and when i try to install it, it goes through everything as it should bu the directory it creates only contains two folders, CUTS and DATA. There's no .exe for me to patch or to run with vDMsound. I tried various things to get it to work without much luck and so i ripped the whole CD to my hardrive. This means i can put the patch in the same directory as the UW executable and thus makes it run. All good apart from i've got no sound and as i have not installed the game running there is no sound card details to edit 🙁
Basically my main problem appears to be that i can't install the game from the CD and therefore can't get any sound. Any help would be much appreciated.
