First post, by Robin4
Does somybody has the american or english version of that compaq MS-dos 3.31..? Its very expensive to find it second hand. And besides its very hard to find.. Someone can help me to get my XT computer a live??
Reply 1 of 14, by Davros
does it have to be compaq ?
wont plain dos do the job
Reply 2 of 14, by DonutKing
Compaq DOS 3.31 has FAT16 support (so works with partitions over 32MB) which is probably what he's after. Whereas MS-DOS 3.3 only supports FAT12 and partitions <32MB
Of course, DOS is still under copyright so I don't think this is allowed here...
Reply 3 of 14, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yeah I was wondering what the goal is of that request. Sharing of copyrighted software isn't legal and trading of goods is not allowed here...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 14, by Robin4
For now normal dos 3.31 as 720KB bootfloppy would be nice..
But i need to make an bootable under windows 7, otherwise i cant boot up my XT system.
Reply 5 of 14, by DonutKing
There was no MS-DOS 3.31; that was a Compaq only version. Microsoft went from 3.3 to 4.
I'd suggest you avoid MS-DOS 4 though as it had some data corruption bugs (supposedly fixed in 4.01 but I stil ldon't know if I'd trust it)
MS-DOS 3.3 supports 1.4MB disks so unless you actually have a 720kb drive you don't need 720kb boot disks. Or does your motherboard only support 720kb drives?
Reply 6 of 14, by Zup
I've seen something labelled as Compaq DOS 3.31 in an abandonware site. I guess that googling the terms will give you another results.
I'm selling some stuff!
Reply 7 of 14, by robertmo
also check buccaneers bay or sth like that 😉
Reply 9 of 14, by Robin4
Yes XT motherboards support only 720KB drives.. BUT that kouwell KW-530D floppy drive controller that iam using has support of 360 / 720KB, 1.2MB/ 1.44MB drives..
I know 100% for sure the floppy drive it self is an sankyo 1.44mb drive. Because i have tested it when it was connected on the 386 motherboard the case came with..
I think that the onboard floppy drive controller bios is non-working.. Maybe the rom is dead so i goes back in 720KB mode..
I tried to run elevator on dos 6.22 bootdisk on this XT system, but wont load. I think that MS-dos version takes to much ram.. so i kills to load the game..
Reply 10 of 14, by Robin4
Davros wrote:
have you got access to a win 9x pc
you could use it to make a dos boot disk
http://www.youtube.com/watch?v=AjUMOghzAuY
I have to wait when i get an ATX enclosure with ATX PSU otherwise i cant use my Athlon socket A system.
Write floppy disks on my windows 7 system does work on my older systems..
May i ask which files on those compaq 3 floppy disks?
1. MS-Dos startup (is this the boot disk?)
2. Fastart (is this the setup for installing ms-dos on harddisk?)
3. MS-dos operating (i think this is the operating system install files)
So.
1. I need to boot up the system with boot floppy..
2. Required to install ms-dos 3.31 on harddisk
3 Then use the dos installation files to install dos..
(is this correct..)
Can somebody make an tree which files are on those floppys..
Reply 11 of 14, by ADDiCT
Exactly how is this going to help you?
Reply 12 of 14, by Robin4
Just what i ask ???? Please answhere my questions..
Reply 14 of 14, by Davros
then post how much memory elevator needs also post the contents of your config.sys and autoexec.bat (from dos 6.22) and im sure we can free up enough memory
