First post, by tikalat
Chex Quest (1996)
Chex Quest 2 (1997)
Doom (1993)
Doom II: Hell on Earth (1994)
Final Doom (1996)
HacX (1997)
Heretic (1994)
Heretic: Shadow of the Serpent Riders (1994)
Hexen: Beyond Heretic (1995)
Hexen: Deathkings of the Dark Citadel (1996)
Raptor: Call of the Shadows (1994)
Strife (1996)
Ultimate Doom, The (1995)
Title: Driver fixes
Date: July 7, 2013 (#2)
About:
General MIDI
- Send GS reset
- Disable GM off sysex
Generic patcher for Doom engine games. May add reverb to some Yamaha cards. Compatibility fix when game shutdown (GM off = borks some devices)
v2 - add Raptor: Call of the Shadows
    Doom engine - genmidi.7z
    359.42 KiB
    717 downloads
    v2 kit - DOS
Reply 3 of 18, by tikalat
Started looking at Doom2 first.
D_DDTBL2.mus / D_DDTBL3.mus / D_DDTBLU.mus / D_DOOM.mus / D_DOOM2.mus
- Castanets, Shaker (3+ each)
D_STALKS.mus / D_STLKS2.mus / D_STLKS3.mus
- Castanets, Shaker, Mute Surdo (3+ each)
D_DM2INT.mus / D_OPENIN.mus
- Instrument = Fl. Key Click
- Each has only 1 note
(needs checking I guess)
Confirmed D_STALKS.mus (M2) plays GS percussion in logs. Like 12x each.
Reply 5 of 18, by tikalat
Check around 1:32 for D_DM2INT. You'll see program change and there should be around 6 hits total from then on.
http://www.doom.com.hr/public/doom2/music/midi/
Thanks for the D_OPENIN info.
Problem is going to be... how to fix this? Unless there's a bank controller I didn't see. And then patching the wad files to include the changes. Hmm..
Did check Doom 1 - very clean. No GS percussion / banks.
Reply 7 of 18, by tikalat
I checked the mirsoft MIDIs. They look wrong - zero program changes once score starts. Doom 2 raw recordings have lots of patch modifications mid-track.
There's just 1 soundtrack that covers both FM + MIDI.
Reply 8 of 18, by keropi
it seems there isn't a source to get good midis... sad for people that leave game soundtracks playing in the background 😐
Reply 10 of 18, by tikalat
Heretic
MUS_CPTD.mus / MUS_E1M2.mus / MUS_E1M6.mus / MUS_INTR.mus
- Shaker
Hexen
BLECHR.mus / CHAP_2R.mus / CRUCIBR.mus
- sticks
CHAP_1R.mus / CRUCIBR.mus / JACHR.mus / LEVELR.mus / PERCR.mus / VOIDR.mus
- shaker
CRUCIBR.mus
- metronome bell
FALCONR.mus
- jingle bell
BLECHR.mus
[001A4E] 00 ____ 99 2A 41
[001A52] 6B ____ 89 2A 40
[001A56] 1C ____ 80 1C 40
[001A5A] 33 ____ E1 00 1D
[001A5E] 2A ____ B1 07 3C
[001A62] 00 ____ 99 2A 27
[001A66] 07 ____ E1 00 1C
[001A6A] 5D ____ E1 00 19
[001A6E] 1D ____ 89 2A 40
note: methinks pitch wheel error; next program is Slow Strings much down later
[001A72] 15 ____ E1 00 18
[001A76] 4F ____ B1 00 2D(@@@ GS bank select - high) (###)
[001A7A] 00 ____ B1 07 37
[001A7E] 00 ____ 99 2A 41
[001A82] 0E ____ E1 00 16
[001A86] 2B ____ E1 00 15
[001A8A] 40 ____ 89 2A 40
[001A8E] 1D ____ E1 00 12
[001A92] 39 ____ E1 00 11
[001A96] 1D ____ 90 1D 7F
[001A9A] 00 ____ B1 07 32
[001A9E] 00 ____ 99 2A 20
[001AA2] 4E ____ E1 00 0E
[001AA6] 16 ____ 89 2A 40
[001AAA] 1C ____ E1 00 0D
[001AAE] 64 ____ E1 00 0B
[001AB2] 00 ____ B1 07 2D
[001AB6] 00 ____ 99 2A 32
[001ABA] 32 ____ E1 00 09
[001ABE] 2B ____ 89 2A 40
[001AC2] 4F ____ E1 00 07
[001AC6] 32 ____ E1 00 06
[001ACA] 07 ____ B1 07 28
GROVER.mus
[000066] B6 07 64
[000069] C6 2E
[00006C] B7 07 64
[00006F] C7 30
[000072] BF 07 64
[000075] CF 00
[000078] BF 07 64
[00007B] BF 07 64
[00007E] C9 71 (@@@ GS drum kit = ELECTRONIC + SFX) (###)
[000081] BF 07 64
[000084] 20 --
[000085] 93 1D 50
[000088] 9F 24 4C
[00008B] 9F 2A 40
[00008E] 10 --
[00008F] 8F 24
[000091] 8F 2A
[000093] 30 --
[000094] 9F 2A 49
[000097] 11 --
[000098] 8F 2A
[00009A] 10 --
; normally this would be sticks
[001360] 1F 1F 45 (@@@ GS percussion = Drum kit 114 - Instrument 31)
[00137D] 1F 1F 17 (@@@ GS percussion = Drum kit 114 - Instrument 31)
[001397] 1F 1F 3D (@@@ GS percussion = Drum kit 114 - Instrument 31) (3+)
NewRisingSun says 71h = ELECTRONIC + SFX (SC-55).
I wonder what SC-88 would do here...
VSC reverts to STANDARD (as expected).
Roland experts? 😀
Good news is that Hexen actually sent bank controller change. So I can punch it into Doom2 MIDIs and figure out how to rewrite WAD later.
Going to check out more games before updating the master list.
Reply 12 of 18, by tikalat
SC-88 has that 'No instrument' message when using melodic CTF. I wonder if it does the same thing with 'bad' drumkits (no percussion plays)? Or does this special drumkit even exist on SC-88?
To be more precise, does the percussion sound the same on SC-88 vs SC-55 non-GM vs Yamaha when using this drumkit? I'm just crazy curious if it actually sounds different or not. ^^
Reply 13 of 18, by d1stortion
Ah that's what you meant. No, I believe it'll show a "No DRUM SET" and stay on whatever last drum set was played. And maybe I misunderstand something here, but there certainly are SFX and ELECTRONIC drumkits; what is meant with this combination?
About Hexen: I've never seen this game use any GS drumsets (ingame that is), so I'm a bit surprised that you come up with this. Do you want to say it's supposed to do so but something went wrong with the driver? It doesn't show No DRUM SET...
Also, I just tested Doom2 entryway on my SC-88. With the regular map it simply doesn't have that "muted" cymbal behavior, regardless of GS/GM mode. It's like the Yamaha GM recording I posted. Turning on SC-55 map, everything is like on the SC-55 or TG300B Yamaha recording, both modes. This really points at the SC-55 sample set being the cause of this. So in that respect, Yamaha's Roland compatibility mode is rather elaborate, switching out those samples...
Reply 14 of 18, by tikalat
I don't know. It's what NewRisingSun said once in the Sierra thread when I asked about his SQ5 driver. So I only know based on that - I take his word that it exists but don't know how it sounds / works. xx(
For Hexen, type this: visit11
https://doom.wikia.com/wiki/Hub_2:_Sacred_Grove
raw midi capture
[0002C7] 00 ____ B5 07 40
[0002CB] 00 ____ C5 30 (program)
[0002CE] 00 ____ B6 07 40
[0002D2] 00 ____ C6 2E (program)
[0002D5] 00 ____ B7 07 40
[0002D9] 00 ____ C7 30 (program)
[0002DC] 00 ____ B9 07 40
[0002E0] 00 ____ C9 00 (program)
[0002E3] 00 ____ B9 07 40
[0002E7] 00 ____ B9 07 40
; Drum kit here...
[0002EB] 00 ____ C9 71 (program)
[0002EE] 00 ____ B9 07 40
[0002F2] 81 64 ____ 93 1D 50
[0002F7] 00 ____ 99 24 4C
[0002FB] 00 ____ 99 2A 40
[0002FF] 72 ____ 89 24 40
[000303] 00 ____ 89 2A 40
[000307] 82 57 ____ 99 2A 49
[00030C] 79 ____ 89 2A 40
[000310] 73 ____ 99 24 47
[000314] 72 ____ 89 24 40
[000318] 72 ____ 99 2A 47
[00031C] 72 ____ 89 2A 40
[000320] 82 5E ____ 99 2A 49
[000325] 73 ____ 89 2A 40
[000329] 82 57 ____ 99 24 51
[00032E] 00 ____ 99 2A 4E
[000332] 72 ____ 89 24 40
OOh. Nice find!
Reply 15 of 18, by d1stortion
Well, if you don't see that it exists on VSC then it doesn't exist on SC-55 either...
About Hexen: yeah, wtf. Do you already have any clue what causes this? I mean literally, most/all of the other tracks are using STANDARD...
Reply 16 of 18, by tikalat
Checked all of VSC documentation and nothing about drum kits 70h - 73h. Just 7Fh = CM-64 / 32L. I'll remap it to STANDARD.
Drum kit is hard-coded into the physical MIDI score itself. It's the only one in any Doom-engine game so far.
(Raptor: Call of the Shadows = plain GM)
GROVER.mid uses ch1-8 + ch10. The way the setup is structured, it seems like to me C9 71 was originally another channel that got dropped. But author forgot to cleanly fix it.
[000042]  B0 07 64
[000045] C0 2D
[000048] C1 59
[00004B] B1 07 64
[00004E] C2 36
[000051] B2 07 64
[000054] C3 3D
[000057] B3 07 7F
[00005A] C4 20
[00005D] B4 07 64
[000060] B5 07 64
[000063] C5 30
[000066] B6 07 64
[000069] C6 2E
[00006C] B7 07 64
[00006F] C7 30
- Doom engine maps this to ch10
[000072] BF 07 64
[000075] CF 00
[000078] BF 07 64
[00007B] BF 07 64
- Originally unused channel 9,11-15?
[00007E] CF 71
[000081] BF 07 64
I believe you're right - it's STANDARD. Will fix that too. Thanks! 😀
Reply 17 of 18, by tikalat
Strife has no GS percussion. But 1 drum CTF
D_SLIDE.mus
; CTF = Jazz
[000019] C9 26
[00001C] 99 29 51
[00001F] B9 0A 32
[000022] 99 24 63
[000025] 99 26 43
Track has 1 instrument - percussion channel only. So it looks intentional enough.
So Hexen + Strife are now added to patcher. But there's this too:
http://www.doomworld.com/vb/source-ports/5445 … m-sfx-format/1/
Reply 18 of 18, by Daemonrunner
Thank you for this!
I have no idea if there is a real difference between GS or GM in Doom, but the fact it is using the SC-55 mapping on the Roland SCVA as opposed to GM mapping makes me feel better! 🤣
