HUGE problem
First post, by AlexDroog
Whenever I play a game with video it crashes, always, every game. I tried different sound cards, video cards and even a different cd-rom drive with no luck. It even crashes when playing video off the hard drive. I tried different autoexec.bat and config.sys configurations but nothing works. If I disable sound everything is fine. Sound and video cant play at the same time for some reason. I tried everything I can think of except trying another motherboard and controller card. This is a complete mystery to me. This never happened to me 20 years ago when I used DOS pc's
Reply 1 of 17, by Mau1wurf1977
Some ideas:
Use a different CD-ROM driver. I recommend the one from Acer. It's VIDE-CDD.SYS. http://www.mdgx.com/drv.htm
Apart from that you have't told us anything to work with. Tell us everything about your system!
My YouTube channel
Reply 2 of 17, by AlexDroog
I tried the vide-cdd.sys driver and it still doesn't work.
My system is
486DX2-66
Magitronic GA-486-VC socket 3 motherboard
16mb 30 pin 70ns simm memory
Real Power 230 Watt AT power supply
Diamond Viper Weitek power 9000 vesa local bus video card
Vesa local bus IDE controller card
853mb Western Digital Caviar 2850 IDE hard drive
Hitachi CDR-7730 4x IDE cd-rom drive
Sound Blaster 32 CT3600
Midiman MM-401
Roland MT-32 (old)
DOS 6.22
Reply 3 of 17, by Jorpho
Perhaps it is some sort of IRQ problem. Can you post your autoexec.bat and config.sys ?
Also, are your hard drive and CD-ROM both plugged into the VLB controller card?
Reply 4 of 17, by AlexDroog
Yes, the hard drive and cd-rom drive are plugged into the VLB controller. Hard drive is master and cd-rom is slave. Here are my autoexec.bat and config.sys. I have 611K of conventional memory with this setup
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P300 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
C:\CTCM\CTCU /S
@echo off
SET PATH=C:\DOS
C:\DOS\SMARTDRV.EXE
LH=C:\VESA\VPRMODE.EXE VESA
LH=C:\MOUSE\CTMOUSE.EXE
LH=C:\DOS\MSCDEX.EXE /D:MSCD001 /M:15
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=45
FILES=30
DOS=UMB
LASTDRIVE=E
FCBS=4,0
DEVICE=C:\CTCM\CTCM.EXE
DOS=HIGH
STACKS=9,256
DEVICEHIGH=C:\CDROM\VIDE-CDD.SYS /D:MSCD001
Reply 5 of 17, by Davros
what happens if you play the vid from a hdd ?
Reply 6 of 17, by AlexDroog
It does the same thing from the hard drive. If I select no sound and play a video it works, I tried it with two games so far. If I enable sound it crashes when the video plays weather its playing from the hard drive or cd-rom drive.
Reply 7 of 17, by Jorpho
Well, does it make any difference if you disable the CD-ROM drivers? Or SmartDrive?
Also, I think you need to use "DOS=HIGH,UMB" in your config.sys (preferably after HIMEM but before EMM386); I'm not sure it works on two separate lines.
Reply 8 of 17, by RacoonRider
I'm surprised that no one mentionned this before, but these are general sympthoms of PSU failure. I've experienced this a dozen times on more modern systems and it was always the PSU.
btw, never plug HDD and CD-ROM on the same cable. It makes HDD run a lot slower.
Reply 9 of 17, by badmojo
I didn't know that, I'll have to check my systems - I think I'm doing that in a couple of them.
Reply 10 of 17, by Davros
try removing
BUFFERS=45
FILES=30
FCBS=4,0
STACKS=9,256
also try differnt dos versions including dr dos
Reply 12 of 17, by Jorpho
Davros wrote:
ps: are you using the ide port on the sb16 ?
It's an SB32.
Reply 13 of 17, by AlexDroog
I have tried everything. I'm going to get another motherboard. Perhaps that's the problem.
Reply 14 of 17, by Calvero
Are there any memory settings in the BIOS?
Reply 15 of 17, by AlexDroog
Yes, I have tried every different setting for memory in the bios and it doesn't work. I think I found the real problem.
Reply 16 of 17, by RacoonRider
Perhaps you could reveal the secret
Reply 17 of 17, by AlexDroog
Its fixed. It was my vlb controller card.
