LucasArts Patches.
First post, by FeedingDragon
OK, In the process of going through my collection and testing games to see which ones need to be played on DOSBox and which ones I can put on my vintage system (well, late 90's era system.) I prefer to play most games on the vintage system for a variety of reasons, and in many cases all I need is a patch. Until now, I haven't had much problems finding those patches, if they ever existed at all that is.
My current test game is Indiana Jones - The Last Crusade (graphic adventure.) Can not use AdLib music because of my system speed. Web searches show a patch existed (486 upgrade patch,) that might work, but I cannot find it. Every result I come to either points to the LucasArts page (which was replace by Disney as a Star Wars page,) or goes to ScummVM (which is not what I'm looking for.) The only file I can actually download, that I've found, was for the German version only.
I faced the same problem with X-Wing (and probably will with TIE Fighter as well,) but managed to find (ok, someone gave me,) an archive site. I'll probably face it again with future LucasArts games (I know I also have TIE Fighter, Fate of Atlantis, several Monkey Island games, maybe more.) Does anyone have, or know of, any archives of patches for these games? Those that have the original patches that existed, and not ones that just point to ScummVM or take me to Disney?
Thank you 😀
Feeding Dragon
Reply 2 of 19, by FeedingDragon
Currently it is a P3-333 system (under-clocked because of MB issues.) It will eventually be a P3-800Mhz system. MB issues prevent me from disabling the cache (won't boot, and slow-down SW crashes the system.) Many of the games that I may be relegating to DOSBox are going to be re-tested when the MB is replaced. But many of my games play just fine, they just need something to tweak the speed issues. A lot of Sierra titles (for example,) have problems with their SoundBlaster drivers, but the patch(s) I download work just fine. I've read that the patch for "Indiana Jones: The Last Crusade" doesn't always work, but would like to try it (primarily after I replace the MB and/or V2 cards,) anyway. Only, it seems to have disappeared. All the links I've found have been removed or replaced (except the German one.) 🙁 Usually, I can find them archived "somewhere" but not this time.
Feeding Dragon
Reply 3 of 19, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Found the 486 patch for Last Crusade in my archives, but note that it's for the 256-color upgrade version, not the original 16-color version. I may have other LucasArts patches stashed, but it's probably hit and miss. Maybe someone backed up the LucasArts FTP server before it went offline.
    indy256.zip
    54.76 KiB
    511 downloads
Reply 4 of 19, by FeedingDragon
I'm hoping that as well. The 256 color version is the one I have. I may have an older version around somewhere, but I sort of doubt it (unless it was part of a compilation or batch purchase I didn't notice.) I couldn't begin to list my games collection just from memory. Something like 10 large boxes full (each box can hold from 10 to 30 games easily.) Fully half of them are unreachable in storage 🙁
Thanks for the file, I'll check it out. May not work with this MB, or it may work with this one but not the replacement. I'll find out 😀
Feeding Dragon
Reply 5 of 19, by Jepael
Sometimes increasing the 8-bit IO recovery cycles in BIOS settings help with Adlib music in games. Also try to slow down the ISA bus clock to slowest possible setting. Too bad you cannot disable the caches, that would also be one of my standard suggestions.
The trick may not work however, because at least in Monkey Island the Adlib writes are timed with a delay loop instead of the default way of doing dummy IO reads between IO writes to OPL chip registers, so the extra wait states have no effect on delays between writes then.
Having said that, as OPL3 chip can be accessed with much smaller delays than an OPL2 chip, can you try a OPL3-based card in your system?
Reply 6 of 19, by FeedingDragon
I'm actually building this system around my AWE32 and MPU-401 cards 😀 Several of the replacement MBs I'm looking at (won't be able to actually buy one till my refund on my last failed replacement hits,) have IO wait states (don't know about setting ISA bus speeds,) but this one doesn't 🙁 I'm hoping the new MB will allow SW disabling of the cache as well (so I can disable it for specific games and not for others.) I generally avoid using slow down utilities (MoSlow etc..) but will in some circumstances. They sometimes function unreliably (semi-random bursts of speed that can alter game mechanics.) Most times, if speed is an issue for game play, I move it to DOSBox. It's just games like this one, where game play is unaffected and it's just the driver that has an issue, where I will look for alternatives (driver replacement, slow down utilities, etc...)
An exception to the above rule of thumb, flight games and such I will move heaven & earth to get working on the vintage system. Even to having special boots, or having to go into BIOS before playing them. I like my Thrustmaster, and don't have one for my modern system. Not sure if I'm going to get one for it or not. On my old vintage system, I actually had Wing Commander running smoothly (though I don't remember the exact mechanics.) But it was only 233Mhz, and the SW cache disabling software worked just fine. I'm fairly sure that all I did was disable the cache, but that HDD was wiped long ago 🙁 I was in a hurry and forgot what I had on it.
Also, just to note, with this MB, the patch doesn't help. Indy256 will still only work with PC speaker. I'll try when the new MB gets here. I'll also be re-testing a dozen or more other games as well. I'm already moving on to my next game. Thanks for your help, and I'm still looking for anyone who knows of or has LucasArts patches archived.
Feeding Dragon
Reply 7 of 19, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I've noticed that with high cycles in DOSBox the 486 patch executable doesn't play AdLib music, but it does when you specify AdLib with a parameter "INDY256 a". Forcing it like that probably bypasses detection, which may be useful in your situation, but for a P3 it's far from a certain thing.
Reply 8 of 19, by Great Hierophant
I have troubles with Adlib and games like Indy, Loom and MI1 in a 486. Usually turning off the CPU cache fixes them.
I made sure to grab all the LucasArts patches for any PC game released during the 1980s and 1990s from their Yoda's Help Desk well before they were purchased by Disney.
Reply 10 of 19, by FeedingDragon
Thanks 😀 I would have preferred to pick and choose over a single archive, but 2.45G isn't all that bad. I'll look around and see if someone has a relatively frequently updated site where the individual patches could be hosted 😀
Feeding Dragon
Reply 11 of 19, by Stiletto
Actually you CAN browse within and download individual files on some of these archives, it's just that the interface sucks.
I go into some detail describing how here:
Re: Preservation of historical ftp site content
Doesn't seem to apply to this specific one, however.
do the Fandango!" - Queen
Stiletto
Reply 14 of 19, by Stiletto
Or click "HTTPS" in the top left, which takes you to a folder directory, from which you can download the 2.45 GB TAR which contains everything the FTP contained on 04-27-2013.
But downloading the torrent might actually allow you to pick and choose which file you want (depending on your torrent client).
Stiletto
Reply 15 of 19, by njaydg
Sadly, even the torrent has the huge 2.45GB compressed file in it, so we have to download the whole thing.
Hey, it's much better than not having it at all... History of (old) gaming must be preserved! 😀
Well I'll be...! For those who don't want to download the whole FTP archive, Disney actually put some links to a few LucasArts's old patches:
http://help.disney.com/articles/en_US/FAQ/Lis … s?section=Games
Ah, there's the patch for Indiana Jones and The Last Crusade I was looking for... 😎
Still, the FTP archive is the place to go, as the Disney link features no documentation whatsoever.
Reply 17 of 19, by leileilol
It's a little ironic when the hosue of mouse treats their legacy game library better than most other companies like Ubisoft, Hasbro, 3DRealm and Zenimax.
you'd think they stick it all up into the Disney Vault(tm)!!!!
(sitll pissed for them dropping mvc3/umvc3 from the market though)
long live PCem
Reply 18 of 19, by DustyShinigami
How exactly do you extract a TAR file?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
