First post, by Totempole
- Member
I've been having some trouble getting a CD Drive to work on one of my machines in MS-DOS mode. I've tried a number of different drives, so can confirm that the drive itself is not the issue.
When I load the driver and test the CD-Rom, the CD Spins up as if it's reading the contents, then says "File Not Found". I've tried using oakcdrom.sys and sscdrom.sys, but the outcome is the same.
This is what my Autoexec.bat and Config.sys looks like:
Autoexec.bat
@C:\LETASSIG\LETASSIG.EXE @LETTERS.INI /O:DRIVEMAP.DAT /CD
SET SOUND=C:\PROGRA~1\CREATIVE\CTSND
SET MIDI=SYNTH:1 MAP:E MODE:0
LH C:\MOUSE\MOUSE.EXE
LH C:\WINDOWS\CTCM.EXE
LH C:\MSCDEX\MSCDEX.EXE /D:MSCD001
Config.sys
LASTDRIVE=Z
DEVICE=C:\WINDOWS\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS
DEVICE=C:\WINDOWS\setver.exe
DEVICE=C:\MSCDEX\OAKCDROM.SYS /D:MSCD001
ANy thoughts on this would be much appreciated. Thanks.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
