First post, by Jackie78
I have just installed Dosbox 0.60, and ant to mount a drive from my real harddisk, but I simply cannot type a backslash on my german keyboard!
Using AktGr+ß (the key next to the 0) doesn't work, and trying the correct Ascii code using alt+92 on the numeric keyboard doesn't work either.
So, how do I make a backslash usigng a german keyboard?
cu,
Jackie
Reply 2 of 4, by Jackie78
thanks for that hint, although that seems quite unusual to me (okay, some unix guys find it normal, but it's quite unusual to dos- and win users).
Isn't there a workaround to simply enter a simple backslash?
Thank you.
cu,
Jackie
