First post, by Elia1995
- Oldbie
Ok, besides the stupid pun in the title with the game's title, I have an issue with ONLY this game and my CT3670 AWE32 PnP sound card.
If I set the SFX on Sound Blaster (naturally), I get the following error when I launch the game:
Invalid parameter in BLASTER environment variable
If I only set the music in AdLib or Sound Blaster and disable sound effects, the game runs perfectly with the music but without sounds.
I also tried enabling only the sound effects and disabling music, but the error is still there.
It seems it doesn't like the IRQ or DMA, but it doesn't let me change them like Duke 3D, Doom and others do and I cannot edit the file hocus.dat.
This happens with this game only, others work perfectly with sound effects and music at the same time.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
