First post, by NeoVamp
Hi, I'm currently trying to setup my dos computer in a way that it does not need to use CDs at all.
Right now I'm working on setting up Quake, I got it set up all nicely with a bat file that allows me to select mission packs and stuff.
But.. to get music from Quake and the Mission packs you need the cds, which I have.. but I don't like having to
swap discs every time I want to play a game. (not to mention the noise that the cd drive makes)
So my question is.. how difficult would it be to add OGG music support in dos quake?
The source is available, but would it even be possible under pure Dos?
Pentium 1 - 233MHZ MMX / 96MB / Soundblaster AWE32 / MT-32 / SC-55 / SB-55
Diamond Stealth 64 / Diamond Monster 3D (4MB) / Dos 7.1 / 120GB IDE HDD
Reply 3 of 9, by NeoVamp
ibm5155 wrote:
Also, just wondering, if there's a way to play the music files from a iso
iso is sadly just for data, or I would have used SHSUCD to play the music from an iso.
Reply 4 of 9, by mr_bigmouth_502
If someone ever figures out how to emulate a CD-ROM drive under pure DOS with CD audio support, I think they deserve a medal. Even a solution that works on Win95 without having to install IE4 (yuck) would be great.
Reply 5 of 9, by leileilol
There was a "QDOS" port that might or might not do this. i forget
As for adding streaming music into quake, good luck. Usually the problem is trying to paint consistently into quake's wacky sound buffer code.
I wanted Engoo's DOS version to have DUMB's mod playback and ogg playback at one point. Was able to put libxmp into Q3 though, where the sound code is a little less wacky
Reply 6 of 9, by NeoVamp
Found it and apparently it supports both OGG and Wav!
OGG and WAV streaming music in the form of id1/music/trackxx
Gonna try it out and will let you guys know if it works.
Reply 7 of 9, by gdjacobs
I speculated a while back if a hardware solution in the vein of the Gotek would be possible.
Reply 9 of 9, by NeoVamp
QDOS plays the music perfectly! Thank you very much for telling me about it leileilol. (and Maraakate for creating it!)
