First post, by koifish
I've edited my original post to reflect changes in my situation.
This is a problem for DOS programs that run within Windows 98 as well, they load a black screen, but I can exit them by using Alt+Enter to go to windowed mode. It gives an error and says it cannot run the program in Windowed mode. At that point all I can do is close the program out. Unfortunately I cannot seem to do this when the program is running under MS-DOS mode.
The biggest issue is that after trying to run a DOS program in MS-DOS mode, the system has gotten itself into a boot loop. I can access BIOS but if I try to boot Windows 98 then I only get the same "Windows is now running your MS-DOS program" message and then a black screen. If I press ctrl-alt-del here then it resets the machine, but then goes back to the same "Windows 98 is now running your MS-DOS program" and loads the same black screen. I cannot boot back into Windows 98 desktop.
I am not seeing a loss of video signal, as the monitor still remains active (no standby mode message, power light stays green and doesn't change to amber). Rather it just appears to be sending a black screen.
Here's my system specs from BIOS:
Pentium 4 @ 1.6GHz
512MB 266MHz RAM
nvidia GeForce 200 MX
Gateway on-board sound card
3.5" DS/DD Floppy Drive
CD-RW Drive (not sure on speeds but probably not relevant anyway)
Mine was a thrift store special and I found it as-is, save for the RAM which I added.
What should I do to resolve these issues? Thanks for any help!
