First post, by Robhalfordfan
hi
I posted a while ago about garbled text in pharoh's tomb and there was a fix but a few other games are affected because of this
help with Pharoh's Tomb in dos [SOLVED]
I have made a multiple choice bat file for the game to boot into each episode with slowdown software and I was wondering is there a way to
change country file code in config.sys from a bat file automatically for the game and to automatically change back to original when games exits
or
from a bat file to automatically change lines in config.sys and autoexec.bat from the previous post when game runs and change back when game exits
Reply 1 of 11, by Jorpho
There are utilities like devload and drvload that will let you load .sys files from a batch file, and I think some of them will even let you unload the .sys files later. There should be other threads about them somewhere around here. I don't know if they work with display.sys and country.sys, though.
Reply 2 of 11, by Robhalfordfan
ok thanks and had a go with them and other sys loaders and unloaders doesn't work as some cant find the sys file (eventhough the sys file is there) or if it does, the dos prompt flashes and does nothing
and is there a way to unload a sys file from already loaded config.sys and load the unloaded sys file back after games exits
and noticed I only need to disabled the display.sys for the game from previous post
Reply 3 of 11, by Jorpho
There might be something obscure with that capability, but it probably wouldn't work any better than the .sys loaders.
Since you're using DOS 6.22, wouldn't it be easier to set up a boot menu that doesn't load up the relevant .sys file, and then reboot when you're finished playing the game?
Reply 6 of 11, by Jorpho
People have been doing that for the last twenty years. It is straightforward and you should have no trouble finding a guide on Google.
Have you read anything about it already? Do you have any specific questions?
Reply 7 of 11, by Robhalfordfan
would the boot menu start before the HIMEM checks for memory
could in theory have few boots options like
one with display.sys loaded
one without display.sys loaded
one just for dos networking/bbs stuff
