First post, by Serious Callers Only
Since the game has fairly major performance problems with the dosbox glide patch, and it uses dos4gw, i thought about using dos32a, but it appears to crash (either replacing the dos4gw file or rebinding dos32a to the rgfx.exe or glide2x.ovl files. However, i know dos32a has more settings than are apparent with its executable utilities messing with the exec. I wonder if someone managed to make it work?
