Yes, there is one, indeed.
I d/l'ed it and tried it, and it says "simon.wav not found". I looked on the CD, there's a "simon.voc". So, I did a little bit of research in the net, and found the tool "simon2mp3" that should convert this voc file into a mp3 (the file is NO standard Soundblaster-VOC-File, by the way.)
When I tried to run that tool, it crashed and demanded the lame.exe; so I searched and d/l'ed the newest LAME encoder and put it into the same folder, and tried again to run simon2mp3.
It ran then, converting a whole hour (or so), producing a whole lot of verbose output on my screen.
The mp3 file resulting, though, was no valid mp3 - couldn't open it with any mp3 player/editor.
So, I then forgot the patch and posted here 😉
