Jurassic Park
First post, by seskanda
This game runs fine in Win98SE, the only problem is that it skips the intro and bypasses the main screen where you insert passwords to other levels. 😕 Anybody got a clue why it does this or know of a patch that fixes this? Tried starting the game with INTRO.EXE and OUTRO.EXE, but nothing happens.
Now, in DOS mode, the intro and main screen work, but the sound effects are messed up, and there is loud jarring noises, beeps, etc. that occur at random, also, the laser weapon sounds completely distorted, as well. However, other sound effects, such as the sounds of the dinosaurs seems to work fine, as does the music. Here are my specs:
Motherboard chipset is Intel 82440BX/ZX
Processor is GenuineIntel Pentium III@550 MHz
64 MB SDRAM (PC100)
nVIDIA Vanta w/8 MB SGRAM
Cirrus Logic CS4614/22/24 PCI CrystalClear SoundFusion Audio Accelerator (a.ka. Crystal SoundFusion(tm) CS4280-CM PCI Audio Accelerator).*
Windows 98 SE 4.10.2222 A
Creative Labs Sound Blaster AWE64 ISA (CT-4520) w/512K DRAM.^
Jurassic Park v1.32P
*= sound card is onboard (i.e. soldered on my motherboard)
^= I'm using this card to play the game.
From AUTOEXEC.BAT:
SET SOUND=C:\Progra~1\Creative\CTSND
SET MIDI=SYNTH:1 MAP:E MODE:0
C:\windows\ctcm
C:\Progra~1\Creative\CTSND\DIAGNOSE /S
REM [Header]
@ECHO OFF
REM [DVD-ROM Drive]
REM c:\windows\command\mscdex /d:gem001
REM [Miscellaneous]
REM [Display]
REM [Sound, MIDI, or Video Capture Card]
REM [Mouse]
From CONFIG.SYS:
DEVICE=C:\WINDOWS\HIMEM.SYS
DOS=HIGH
DEVICEHIGH=C:\WINDOWS\EMM386.EXE RAM MIN=0 D=64
BUFFERS=11,0
FILES=30
FCBS=4,0
LASTDRIVE=F
Thanks.
